3950X SFF Cooling
Solved by Mateyyy,
The NH-L12 is about the best cooler you can fit in the Ghost S1. It will handle a 3950X fine, especially with a slight undervolt. In fact, you can generally get away with even an NH-L9a if you're undervolting, though if you can get the L12 then there's not much point in going that route.
voltigeurramon ·
Posted in Troubleshooting0 -
Vibora ·
Posted in New Builds and Planning4 -
4
3
Doctah ·
Posted in Peripherals3 -
6
michaelb198 ·
Posted in Peripherals2 -
errorcode123_dindin1 ·
Posted in Graphics Cards5
