Need help to solve CPU bottlenecking
Solved by Chris Pratt,
The monitor has nothing to do with performance or framerate and certainly isn't bottle necking anything.
Your issue is the CPU and RAM, but upgrading those will require a new mobo, as well. There's no cheap way out here. You basically overbought on the graphics card. It's more powerful than your system can make use of.
1
toxic_worper ·
6
1
voltigeurramon ·
Posted in Troubleshooting2 -
1
1
Vibora ·
Posted in New Builds and Planning6
