Slightly longer question so bear with me here...
The cooler I have right now is a Scythe Fuma 2 with the front fan replaced with a Corsair LL120.
My plan is to add two more fans to my system (Noctua Redux). The two configurations I can use are:
A NF-P12 (120mm 1700) RPM replacing the middle fan on my cooler (Scythe Kaze Flex 1200RPM), and a NF-14s (140mm 1500RPM) as an intake fan. (Noctua fan is roughly 40% better than the Scythe)
Or
Keep the Scythe fan where it is, get two NF-14s (140mm 1500RPM) fans and use them both as intake.
(The other two fans in my system are a Corsair LL120 and a Scythe Kaze Flex Slim, both as exhaust.)
Which configuration would give me better cooling?
https://linustechtips.com/topic/1226950-fan-configuration/
What the current case and fan setup there is? If you will use same fans and all of them, it matters very little which way you place them. Placing more powerful fans on CPU cooler means lower CPU temps, placing them on case might mean lower temps for both CPU and GPU.
^^^^ That's my post ^^^^
vvvv Who's there? vvvv
https://linustechtips.com/topic/1226950-fan-configuration/#findComment-13861702
As long as the airflow isn't adequate he could put any number of fans on the cooler, it wouldn't make a difference.
I'd recommend using the cpu cooler with the stock fans, 2 corsairs as exhaust and 2 140mms as intake (in a case without extremely restrictive front panel).
If you did end up buying the 280x, I think the bottom fan positions would be more beneficial (unless you have it on a carpet). With a bottom> top airflow the only "danger" is a hot air pocket above the gpu, but I think the aircooler would do a good job at stirring up that area.
If you have some other case with a restrictive front the 120mm corsair might do a better job at pulling air inside, since 120s tend to have better pressure.
My R2700XT build:  r7 2700 @4.1 Ghz max 65C - Sapphire Pulse rx 5700xt @1625Mhz 955mV 1300rpm fans, max 82C - Asrock B450 gaming k4 - Gskill Ripjaws 2x8GB @3200mhz CL16 - Be Quiet Straight Power E11 650w - Fractal Meshify C - EK-Kit S240 - NB eLoop 120mm PWM - Be Quiet Shadow Wings 140mm 1000rpm - Bitfenix Spectre LED PWM 120mm - Samsung 250GB 860 Evo - Seagate Barracuda 2TB
Peripherals:  Acer XF270HBbmiiprzx 144hz 1080p TN - CM Storm Quickfire TK - Coolermaster MK750 - CM Storm Reaper - Logitech G303 - Logitech G502 - Logitech G603
Audio:  Hyperx Cloud Stinger - Samson SR850 - Trust Screamer - Creative Gigaworks T20 II
https://linustechtips.com/topic/1226950-fan-configuration/#findComment-13866256
