I'm running the ASUS x570 "TUF" (Wi-Fi) Motherboard. Here's the issue:
So I'm having a really strange issue with my setup. My PC was working fine with the latest BIOS, overclock, etc. Now this morning I go to turn it on and it boots for a split second then powers off. Well, I changed the PSU, didn't solve it. Changed RAM, didn't solve it. Changed RAM channels then booted, didn't post. Now I put back my new RAM sticks from before in, mind you EVERYTHING is stock now, go to boot priorities, boot from SSD, and now I'm here on my PC. Clearing CMOS was the only thing making it boot to BIOS. So is it just a funky BIOS? Or something else?
GAMING RIG:
CPU: i9-14900k
MOBO: Gigabyte Z790 Aorus Elite AX
RAM: 64GB G.Skill Ripjaws S5 @ 6000MHz
GPU: Gigabyte Gaming OC ICE 16GB 9070XT
STORAGE: Crucial 1TB NVME (Boot Drive) / 2TB Crucial NVME / 4TB 990 EVO Pro NVME SSD
CASE: Dimas Tech EasyBench V3.0
https://linustechtips.com/topic/1226921-boot-issue-ram-storage/
1 minute ago, gloop said:
Have you tried clearing the CMOS?
Here's the thing. I'm on it now, but the only reason I got it past post was cause I went to boot priorities and launched it from there. If I go to save settings, exit BIOS, then try to post, it won't do it.
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/1226921-boot-issue-ram-storage/#findComment-13860618
just not a stable overclock. it working for a bit does not mean it is fully stable.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1226921-boot-issue-ram-storage/#findComment-13860681
Well now everything is stock, but it won't boot properly without me manually going in and booting it.
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/1226921-boot-issue-ram-storage/#findComment-13860687
so you only boot from the bios?
you can try disabling fast boot, or enabling it if it was disabled.
Build Log:
https://linustechtips.com/topic/1226921-boot-issue-ram-storage/#findComment-13860696
Still won't post doing that. I can't save any changes to the BIOS. I can only go to boot priority and force it to boot from there.
GAMING RIG:
CPU: i9-14900k
https://linustechtips.com/topic/1226921-boot-issue-ram-storage/#findComment-13860735
