Fire up HWiNFO64 and/or Ryzen Master instead, rerun the stress test and then check the temperatures.
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1226734-cpu-package-temp-help/#findComment-13859377
9 hours ago, Mofolodo said:
thid is the result after test.
Have you tried increasing the fan/pump speeds at all?
If the 50-70C reading at idle is also accurate, I would check mounting pressure on the CPU block and maybe even remount it.
Also, try checking in HWiNFO64 what your Vcore is at under load.
https://linustechtips.com/topic/1226734-cpu-package-temp-help/#findComment-13860172
hey just wanted to say i idle at 40-50C and under load its At 75-80C i reaseated the cooler but i think ill have to get a new one i got a 360mm cooler and it didnt fit well with my Gpu so the fans had to go on the other side of the rad and were a little to close to the front panel and not getting to much air ill try with a 240mm cooler and see if changing the position of the rad can help with the temps. or is there other ways to help with this i still have to stock cooler should i try that and see what temps i get?. and strangley my icue is showing the cpu at 35C under load.
Side note the temps dont match is there a problem somewhere.
https://linustechtips.com/topic/1226734-cpu-package-temp-help/#findComment-13861121
