Hi guys,
I bought myself a Asus r9 290x with the direct cu II cooler for my birthday, I really like the card but it gets a little hot while playing games like batllefield 4 like 90 degrees and sometimes has framedrops.
Is this normal? or should I return it and switch to nvidia ?
https://linustechtips.com/topic/122657-290x-issues/
Its normal to run the reference cards to run hot and throttle some bit, but not the DCU 2's. There could be some problem with it apparently the DCU2 290s were recalled for problems with thermals.
EDIT: Just thought of it, try switching it into performance mode, may make more noise but the temps should decrease. If they don't there's a problem with the card.
http://hexus.net/tech/reviews/graphics/65601-asus-radeon-r9-290x-directcu-ii-oc/?page=10
Corsair 400C- Intel i7 6700- Gigabyte Gaming 6- GTX 1080 Founders Ed. - Intel 530 120GB + 2xWD 1TB + Adata 610 256GB- 16GB 2400MHz G.Skill- Evga G2 650 PSU- Corsair H110- ASUS PB278Q- Dell u2412m- Logitech G710+ - Logitech g700 - Sennheiser PC350 SE/598se
Is it just me or is Grammar slowly becoming extinct on LTT?
https://linustechtips.com/topic/122657-290x-issues/#findComment-1631797
Did you try switching to performance mode like Imabigmac'd suggested? It'd entail more noise but should improve cooling. Living in the tropics, temps tend to be a bit high here, especially with the heatwave we are experiencing right now, so I had no choice but to go water cooling. It's awesome to see the GPU idling at 38C with load temp not exceeding 55C....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
https://linustechtips.com/topic/122657-290x-issues/#findComment-1634245
The Hawaii Chip really lives up to its name, given that Hawaii is hot, and the chip itself runs hot. The Chip was designed to run at 90 Degrees, hence the name. After all, how could a chip with 6.3 Billion Transistors in a 245mm Squared Die Area not be running hot.
PC Build
AMD FX 4130@3.8GHz | Sapphire Radeon HD R9 290@947 MHz | 8GB of DDR3 1333MHz RAM | 500GB Seagate HDD | [broken] Cooler Master i600 PSU | Some LG Disk Drive that costed me $20|
https://linustechtips.com/topic/122657-290x-issues/#findComment-1635445
^^ really guys?
Hi guys,
Return it and get Tri-X or TwinFrozr because 290x DCU2 use heatsink that was design for the larger GK110. Hawaii die barely touches 3 of the 5 heat pipes. Overrated Asus.
https://linustechtips.com/topic/122657-290x-issues/#findComment-1636143
