I have a problem with hooking up case fans. The motherboard i am using isn't good for now. I just took a Dell insperon motherboard out of the case to fit a gpu. The pc runs fine but, i think fans would help it preform better. If there is anything I can do before I get my new motherboard.
https://linustechtips.com/topic/1226445-case-fans/
With a case like that, you aren't going to see any performance difference on an OEM board with more airflow. You can either get a fan splitter or molex to fan adapter if you so wish.
Main: AMD Ryzen 7 5800X3D, Nvidia GTX 1080 Ti, 16 GB 4400 MHz DDR4 Linux - Fedora
https://linustechtips.com/topic/1226445-case-fans/#findComment-13857012
You could clean that ridiculous desert, for example.
CPU i7 6700k MB  MSI Z170A Pro Carbon GPU Zotac GTX980Ti amp!extreme RAM 16GB DDR4 Corsair Vengeance 3k CASE Corsair 760T PSU Corsair RM750i MOUSE Logitech G9x KB Logitech G910 HS Sennheiser GSP 500 SC Asus Xonar 7.1 MONITOR Acer Predator xb270hu Storage 1x1TB + 2x500GB Samsung 7200U/m - 2x500GB SSD Samsung 850EVO
https://linustechtips.com/topic/1226445-case-fans/#findComment-13857031
one is a usb connector that should be on the side of your motherboard, other is an audio cable, this is motherboard specific, check your manual.
AMD blackout rig
cpu: ryzen 5 3600 @4.4ghz @1.35v
gpu: rx5700xt 2200mhz
ram: vengeance lpx c15 3200mhz
mobo: gigabyte b550 auros pro
psu: cooler master mwe 650w
case: masterbox mbx520
fans:Noctua industrial 3000rpm x6
https://linustechtips.com/topic/1226445-case-fans/#findComment-13857199
