Hello,
I’m currently in the market for a pair of new speaker cables and I’m kind of confused on what to look for in them.
I recently bought a pair of Kanto TUK and would like to replace the stock cable (not that there’s anything wrong with them) in hopes to get more out of the speakers with better quality speaker cables, I’ve been reading the gains would be minimal?
I’m using the speakers for a desktop and their about 6ft apart from each other if that means anything.
Thank you
i9-9900K @ 5.2GHz 1.39v (Direct-Die) | ASUS ROG Maximus XI Apex | ASUS ROG 2080 Ti O11G | Trident Z Royal @ 4200MHz CL18 | 970 EVO Plus NVMe M.2 500GB | MasterWatt Maker 1200 Plus | Swiftech H360X3 + Nemesis 360 GTX + Barrowch 200mm Boxfish | Lian Li PC-011 Dynamic | Samsung CHG70 32" QLED, 1ms 144Hz | Logitech G815 Tactile | Logitech G Pro Wireless | Logitech G840 | Kanto Yu4 + Kanto SUB8 8-Inch
https://linustechtips.com/topic/1226413-choosing-speaker-cables/
It won't make a difference, most high-end speaker cables are snake oil, the only meaningful difference is shielding.
There was a very famous test done years ago with the highest end snake oil BS cables vs aluminium foil, there wasn't a measurable difference let alone a hearable one.
Sloth's the name, audio gear is the game
I'll do my best to lend a hand to anyone with audio questions, studio gear and value for money are my primary focus.
Click here for my Microphone and Interface guide, tips and recommendations
For advice I rely on The Brains Trust :
@rice guru
- Headphones, Earphones and personal audio for any budget
@Derkoli- High end specialist and allround knowledgeable bloke
General rule the longer you need the thicker it needs to be but that's about all there is.  With 6' probably a 16 gage would do if you want basics.  Shielding is indeed important if the cable runs near things that could do some interference.  None if my cables are shielded.  When you buy a speaker cable get a nice one, it won't sound better but it will be nice to look at if it's exposed.
I9 10850K
EVGA RTX 3080 TI FTW3 ULTRA
32 Gb Crucial Balistix ddr4 3600mHz 16-18-18-38
MSI Z490 Tomahawk
Fractal Design Ion+ 860W platinum
Arctic Liquid Freezer II, 360mm
WB Black SN750 NVMe ssd
TeamGroup L5 3D Lite 1 Tb sata SSD
While shielding is important, the satellite speakers in my bedroom on the nightstands are connected by Ebay 'sort-by-cheapest' speaker cable that runs all the way around the perimeter of the room right next to power cables without an issue. It's up to you how much you want to spend but sometimes the extra money just isn't quite worth it.
@rice guru
Yeah, cheap speaker cables like Amazon Basics Speaker Cables would do a very nice job, forget snake oil expensive cables. I have a friend whose speakers cost an astronomical amount of money (tens of thousands), and he'd used Nordost speaker cables that cost thousands of dollars (with expensive power amp, Super CD player, power line cleaner, etc). To me, it was an obscene amount of money for a sound system, but to my friend's credit, he doesn't waste money on liquor, doesn't smoke, doesn't gamble, is totally faithful to his wife (a rare quality these days), he simply loves great audio.
Yes, the sound was awesome, but I put that to the speakers and his audio gear upstream (other than the cables), had he'd gotten regular red and black speaker cables, I seriously doubt we could have heard the difference. And the sound would be just as awesome....
 Main Rig: AMD AM4 R7 5700X3D (8C/16T) + TR Phantom Spirit 120 EVO | Gigabyte X570 Aorus Xtreme | 2x 16GB Kingston Fury Beast DDR4 3600 | XFX MERC 310 RX 7900 XTX | 256GB Sabrent Rocket NVMe M.2 PCIe Gen 3.0 (OS) | 4TB Crucial P310 NVMe M.2 PCIe4x4 | 2TB TG Cardea Zero Z440 NVMe M.2 PCIe Gen4x4 | 4TB Samsung 860 EVO SATA SSD | 2TB Samsung 860 QVO SATA SSD | 6TB WD Black HDD | CoolerMaster H500M | Corsair HX1000 Platinum | Logitech G915 + G303 Shroud Ed + 8BitDo Ultimate 2.4G | iFi Micro iDSD Black Label | Philips Fidelio B97 | C49HG90DME 49" 32:9 144Hz Freesync 2 | Omnidesk Pro 2020 48" | 64bit Win11 Pro 24H2
2nd Rig: AMD AM4 R9 5900X (12C/24T) + TR PA 120 SE | Gigabyte X570S Aorus Elite AX | 2x 16GB Patriot Viper Elite II DDR4 4000MHz | Sapphire Nitro+ RX 6900 XT | 500GB Crucial P2 Plus NVMe M.2 PCIe Gen 4.0 (OS) | 2TB Adata Legend 850 NVMe M.2 PCIe Gen4x4 |  2TB Kingston NV2 NVMe M.2 PCIe Gen4x4 | 4TB Leven JS600 SATA SSD | 2TB Seagate HDD | Logitech G613 + G703 | SOLDAM XR-1 Black Knight | Enermax MAXREVO 1500 | 64bit Win11 Pro 24H2
HTPC: AMD R7 6800H | 32GB DDR5 4800MHz | AMD 680M iGPU | 2TB SSD (2 Partitions 400GB + 1.4TB)) + 1TB SSD | Logitech G613 + G304 | Win11 Pro  24H2
Laptop: Lenovo Legion 5 Pro 16ACH6H - AMD 5800H | 32GB DDR4 3200MHz | 680M iGPU | 1TB Kingston NV1 NVMe M.2 (OS) | 4TB Lexar NM790 SSD | Win11 Pro
19 hours ago, HenrySalayne said:
Just ignore shielding (why should it be shielded?) and get a decent wire gauge. Any cable will do, preferable copper and I would recommend at least 1.5 mm2 (or something like AWG 16 in stupid units) for up to 10 m.
Shielding is important only if you route the cable through place that could introduce electrical interference.  If not it's not important indeed
I9 10850K
MSI Z490 Tomahawk
5 hours ago, HenrySalayne said:
I can't imagine how in a low impedance circuit (the impedance of the source and the speaker are really low) there could be enough energy radiated into the cables to cause an audible noise or interference. It's no longer a signal level which will be amplified later, it is now a signal to drive a loadspeaker.
This.
On 7/25/2020 at 3:42 AM, ntuason said:
Hello,
Thank you
Just buy any cheap 16AWG+ wire.
As the speakers use 5 way binding posts, I would suggest getting some wire with banana plugs as they're so much easier to use.
Monoprice makes some for pretty cheap, IMO they actually look pretty good. They also have colour coded banana plugs so you won't invert the phase of anything accidentally.
https://www.amazon.com/dp/B01G9BDP7I/ref=twister_B07S57TTFF?_encoding=UTF8&th=1
Just buy a 1 pack. Multiple lengths are available.
LTT's Resident Porsche fanboy and nutjob Audiophile.
Main speaker setup is now;
Mini DSP SHD Studio -> 2x Mola Mola Tambaqui DAC's (fed by AES/EBU, one feeds the left sub and main, the other feeds the right side) -> 2x Neumann KH420 + 2x Neumann KH870
(Having a totally seperate DAC for each channel is game changing for sound quality)
