-asus prime x570-p
-G.SKILL Trident Z RGB 16GB DDR4 3600 (PC4 28800)
-ryzen 5 3600
turn on DOCP, save, exit, PC shuts down and boots up 3 times before it goes into safe mode and gives me this
new time pc builder, partner is shocked this isnt workin. pc been workin fine since i built it 2 weeks ago
https://linustechtips.com/topic/1226358-docp-not-workin/
@lumpenroseTry reseating the RAM.
Upgrade to latest bios.
MSI MAG X670E TOMAHAWK WIFI Motherboard, AMD Ryzen 9 7900X3D Desk-top Processor (12-core/24-thread, 140MB cache, up to 5.6 GHz max boost), CORSAIR VENGEANCE DDR5 RAM 32GB (2x16GB) 6000MHz CL30 AMD EXPO iCUE Compatible Computer Memory, Samsung 990 PRO NVMe M.2 SSD, 2 TB, PCIe 4.0, 7,450 MB/s read, 6,900 MB/s write, Internal SSD, 2 x Seagate BarraCuda 4 TB Internal Hard Drive HDD – 3.5 Inch SATA 6 Gb/s 5400 RPM 256 MB Cache for Computer Desktop PC Laptop (ST4000DM004), MSI MPG A1000G PCIE5 Power Supply Unit, UK Plug - 1000W, 80 Plus Gold Certified, Fully Modular ATX 3.0, PCIe 5.0 GPU, XILENCE XC982 LQ240PRO AIO COOLER, XFX Speedster MERC 310 AMD Radeon RX 7900 XT 20GB 1 x AOC CU34G2XE & 1 x Samsung U32J59XUQ 3840 x 2160 4K, 1 x Samsung Evo 970 Evo Plus NVME PCI-E 1TB, 1 x Samsung Evo 850 250GB, 1 X Sandisk Ultra II SSD 240GB + 2 X 4TB Seagate Barracuda SATA III,  MZHOU 7 Ports PCIe USB 3.0 Card,  2 x UGREEN Hard Drive Enclosure 3.5 inch External SATA Disk Caddy Reader USB 3.0 2.5 3.5 HDD SSD 16TB UASP Case Dock Station With 12V 2A Power Adapter For Windows with 6TB Seagate Barracuda SATA III, Fractal Design Pop XL Case + 4 Fractal Design 140mm Case Fans, Logitech MX Vertical & MX Ergo Trackball Mouse using same USB unifying device, Microsoft Ergonomic Keyboard, Windows 11 Pro x64 Retail, 6TB Seagate USB 3.0 Backup Plus Hub, Blue Yeti Microphone, Logitech C922 Pro HD,  Logitech C920 Pro HD, Bit Defender Total Security 2021.
Second PC (Cyclops) - MSI 990FXA Gaming, AMD FX 8370 4Ghz, Corsair 16GB Vengeance Red 9-9-9-24 1600Mhz, Arctic Cooling Freezer 13, Asus Strix 1050TI 4GB, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 1 x Samsung Evo 850 250GB, 2 X Seagate Barracuda 2TB, 1 X WD Black 2TB, 1 x ASUS 16x DVDRW, X-Case Eagle III Case, 3 X Corsair AF 120 Case Fans, EVGA 850 G2 80+ Gold + PSU, Logitech MX Master Mouse, Corsair K30 Keyboard, Logitech C920 Webcam, R0DE NT1-A Microphone, Scarlet 212 Audio Interface (Revision 2), Windows 10 Pro X64 Retail, Bit Defender Total Security 2021, 2TB Seagate Expansion USB Hard Drive.
Third PC (Old Trustie) - Acer Aspire M3400, OEM Mainboard, AMD FX Athlon II X3 425 2.7Ghz, 16GB Corsair Value 1600Mhz Ram, OEM CPU Cooler, AMD R7 260 2GB GPU, 1 X Acer 27" Full HD Monitor, 1 X Sandisk Ultra II SSD 240GB, 2TB Samsung SATA III, 1 X OEM 16X DVDRW, 1 X Acer OEM Case, 1 X Corsair AF120 Case Can, Corsair CX500 Bronze+ CPU, Logitech MX Master Mouse, Corsair K30 Keyboard, Windows 10 Home X64 OEM, Logitech C920 Webcam, Bit Defender Total Security 2021.
Printers Include - Canon MG5750, Canon, IP8750,  Canon Pixma Mega tank G5050 & 2 X Samsung Xpress C410W.
1 X Zexrow Xbox360 Wired Game Controller.
TP Link Archer AX6000 Cable Router Wifi6 with a Virgin Media Hub 4.0 in Modem only mode running 1GB Fibre internet.
Samsung Galaxy S21+ 256GB Mobile Phone.
Internet Speed.....
https://www.speedtest.net/result/9935039193
https://linustechtips.com/topic/1226358-docp-not-workin/#findComment-13856446
17 minutes ago, lumpenrose said:
-asus prime x570-p
-ryzen 5 3600
Try this, then try using it with DOCP and manually set the frequency to 3200 or 3000, see if it works with that. Also check the QVL for your motherboard to see if your RAM is compatible.
If not, it may work at a lower frequency (3200 or 3000MHz) like mine (Trident Z RGB 3200C16 32gb, runs at 3000MHz with A-XMP/DOCP) does even though it isn't officially supported.
Current System: Ryzen 7 3700X, Noctua NH L12 Ghost S1 Edition, 32GB DDR4 @ 3200MHz, MAG B550i Gaming Edge, 1TB WD SN550 NVME, SF750, RTX 3080 Founders Edition, Louqe Ghost S1
https://linustechtips.com/topic/1226358-docp-not-workin/#findComment-13856468
its compatible i checked. i dont feel comfy updating mobo bios, since ive heard of doing that potentially bricking the mobo, i just spend a whole years of savings to build this PC, im scared of ruining everything so idk if i can do that
https://linustechtips.com/topic/1226358-docp-not-workin/#findComment-13856473
1 minute ago, Nayr438 said:
load the docp and drop the frequency down to 3200 and see if it boots.
If it doesn't
load the docp and go into DRAM Timing Control, set the cas latency to 18 and see if it boots. Says docp is 17-18-18-38
how do i drop the frequency
https://linustechtips.com/topic/1226358-docp-not-workin/#findComment-13856480
I had an unstable boot on 2700x using DOCP and overclocked all core to 4.3Ghz.
Rolled back to 4.2Ghz and all seems fine.
Internet Speed.....
https://linustechtips.com/topic/1226358-docp-not-workin/#findComment-13856491
5 minutes ago, Nayr438 said:
Memory Frequency under Ai Tweaker. Should be the same page you set the docp.
@lumpenrose try 3200 first (using the directions above), and if its stable, great! Otherwise, try 3000MHz
https://linustechtips.com/topic/1226358-docp-not-workin/#findComment-13856495
