I bet you get this question like 1000 times a day, Im sorry.
Im using a 3800x with a Kraken X73 360mm AiO. In Cinebench I get max temps of 75 degrees and when gaming i get 60-65 degrees. Are these good? Forgive me im new to PC. Idle is around 32-35 degrees.
Thank you for your answers in advance.
https://linustechtips.com/topic/1226316-3800x-temps/
these are pretty good temps.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1226316-3800x-temps/#findComment-13856036
10 hours ago, CONeill3 said:
Are these good?
yea they are.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1226316-3800x-temps/#findComment-13856039
