So, i definitely have NO idea about wireless networking, but i am looking for a better router than the one that i have at the moment.
And because i have no clue about choosing the right one i wanted your guys help. Our house is quite small but currently i have a single antenna router and it is not enough, so is it true that more antennas = more range? Also we don't have any wireless AC devices but should i just get one for future-proofing? And finally it would be awesome if i can have a good UI so its easy to manage it because currently i have a Belkin router and the UI is terrible.
Any brand recommendation? I will be buying on chile and on an specific store so this are the options:
https://www.pcfactory.cl/?categoria=88&papa=634&TF=r@1,r@2,r@3
Also the myDlink app looks pretty awesome, do other brands offer something similar?
Main PC:
ASUS F1A55-M LX, AMD A6-3500, (2x2)gb Kingston HyperX Blu DDR3 1600mhz, Seagate Barracuda 500gb 7200rpm,
 Corsair CX430M, Cooler Master Elite 343, Windows 8.1 Pro 64-bit
Netbook:
Lenovo Ideapad S10-2, Intel Atom N280, (1x1)gb DDR2 667mhz, WD Scorpio Blue 250gb 5400rpm, Zorin OS 9 Lite
https://linustechtips.com/topic/122552-help-choosing-wireless-router/
If you want a DSL modem built in go with an Asus DSL-N55U or DSL-N66U, or if you don't need DSL the RT-N55U or RT-N66U (N66 has 900Mb wireless, and Gigabit Wired the N55 has 600Mb wireless and Gigabit Lan. Range is excellent. Best Router I've come across, I tend to go through routers multiple times a year. So far with my N55U I'm at 6 months with no problems. If you have no AC devices there is no need to go for the AC models.
More antenna's doesn't necessarily mean more range, But its generally a bit of a safe bet, you can get higher gain antenna for certain model Access points.
Range wise D-Link have a few cylindrical designed Wireless routers that excel with range. They have very powerful omnidirectional antenna's there high end ones get so hot they're actively cooled (fan in the bottom). Best range I've seen from a consumer grade wireless router.
Apps IMHO for a router are practically useless considering the amount of time you spend using it.
One Steam to rule them all, One Sale to find them, One Sale to bring them all and with their wallets, bind them! - r/pcmasterrace 17/01/2014
  • CPU: Intel Core i7 6700k
  • CPU Cooler: CM Hyper 212+
  • RAM: 16GB Kingston HyperX Fury 2400Mhz (2x8GB)
  • GPU: Gigabyte G1 R9 390
  • Mobo: Asus Z170-AR
  • PSU: Antec High Current Gamer 900W
  • Storage: 240GB intel 520 SSD (OS), Sandisk 128GB SSD(Other OS) 2x 2TB Seagate Barracuda
  • Case: Fractal Design R4
