I'm planning on creating my own case out of acrylic, and with that i'll be upgrading my rig to haswell as well (haswell - h + space = as well. LOL)
Anyway, first, a parts list:
Asus Impact ROG board
i7 4670k
Evga 780 Ti ACX
2 sticks 8gb 1300 ram
1 ssd, 1 laptop-size hdd
SIlverstone SFX PSU 450w gold
For watercooling:
Impact AIO waterblock (EK or Bitspower)
Full 780 ti waterblock (open for suggestions)
Most compact Pump + Res I can find (open for suggestions)
240mm xflow rad
So my questions for this build:
1. I plan on overclocking, how much would you think I can squeeze out of the CPU and GPU with a 450w PSU? And no, I have no plans of changing the PSU because I want to be as SFF as I can. around 4ghz would be my target.
2. Given said overclocking limits beacuse of PSU, will a 240mm rad be enough for the both of them? My secondary option would be to add a 2nd 240mm rad in this configuration:
PumpRes -> GPU -> Rad -> CPU -> Rad -> PumpRes
3. Given that I'll be watercooling my GPU, would the ACX version be a good choice over the reference version or are they virtually the same card with different coolers? Would you suggest a different card instead? 780 Ti's avaliable locally are the Palit, Zotac, Inno3d, MSI, and EVGA ones.
i5 4670K and a 780Ti on 450 watts? not going to happen... 780 is the highest you can use with a SFX PSU
ITX Monster: CPU: I5 4690K GPU: MSI 970 4G Mobo: Asus Formula VI Impact RAM: Kingston 8 GB 1600MHz PSU: Corsair RM 650 SSD: Crucial MX100 512 GB HDD: laptop drive 1TB Keyboard: logitech G710+ Mouse: Steelseries Rival Monitor: LG IPS 23" Case: Corsair 250D Cooling: H100i
Mobile: Phone: Broken HTC One (M7) Totaly Broken OnePlus ONE Samsung S6 32GB  :wub:  Tablet: Google Nexus 7 2013 edition
Really? Bummer. I wonder how Northwest's Tiki can handle that configuration. It lists both the 4670k and the 780 ti as options in their configuration, and yet they use the same PSU only.
Is is wrong look at the video i linked. It's close but i works.
I actually tried that tool after Freaky_spider's post and found out that @ 4.0 ghz with 100 TDP and 1.25 vcore (i'm not aiming for super-high overclocks anyway, just enough to utilize the CPU being unlocked), and at 90% system usage, it said that at min i'll be using 393w and my recommended would be 443. These tools are even known to overestimate.
