Budget (including currency): $1500 Canadian with taxes (13% tax)
Country: Canada eh
Hey guys, I’m building finally. Is 3700x with 1660 super oc a gud pair? Main use coding and video editing. Gaming just for casual as long as it produce 60 FPS and smooth experience. 120 FPS for FPS games ven I upgrade my monitor. Wat is a gud pair, should I go 2060?
https://ca.pcpartpicker.com/b/7VFG3C   ( my build specs)
Wat do u guys think ?
https://linustechtips.com/topic/1225005-for-my-build/
Country: Canada eh
if its possible, wait a little while. new generation of cpus(ryzen 4000) and gpus(rtx 3000, big navi) are coming out soon by september, pretty sure you can get better components for the same or lesser price.
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845204
that psu tho...
oh well. everything looks pretty good. no a 2060 isnt necessary.
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845208
Just now, AbelT said:
Should I go gold rated psu or more watts ? Wdym for psu?
nah. nothing to be concerned about i think
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845218
Desktop: Intel Core i9-9900K | ASUS Strix Z390-F | G.Skill Trident Z Neo 2x16GB 3200MHz CL14 | EVGA GeForce RTX 2070 SUPER XC Ultra | Corsair RM650x | Fractal Design Define R6
Laptop: 2018 Apple MacBook Pro 13"  --  i5-8259U | 8GB LPDDR3 | 512GB NVMe
Peripherals: Leopold FC660C w/ Topre Silent 45g | Logitech MX Master 3 & Razer Basilisk X HyperSpeed | HIFIMAN HE400se & iFi ZEN DAC | Audio-Technica AT2020USB+
Display: Gigabyte G34WQC
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845220
11 minutes ago, eeeee1 said:
that psu tho...
What's wrong with that PSU? I mean it's priced slightly high for what it is, but that's just life right now.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845251
nothin. just a little concerned about something else.
PC specs:
RTX 2060
NZXT H510
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845262
14 minutes ago, boggy77 said:
Ok ty sir. For the motherboard y is it better than the one I had ? I am new so still getting to know components .thx
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845293
asus b450 boards have pretty bad vrms that can barely run a 3600. it would struggle with the 3700x.
the b550 boards have improved vrms and support pcie4 and next gen (4000 series) ryzen.
as for the other components, the kingston a400 is the slowest ssd on the market
the ram was overpriced and the psu quite bad for a mid-high range build
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13845304
Oh ok yo what do u think of Msi tomahawk max and it’s only $175
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13847181
https://linustechtips.com/topic/1225005-for-my-build/#findComment-13847708
