corsairs Rm series
Specs
https://linustechtips.com/topic/122477-psu-help/#findComment-1629604
How about the Seasonic Platinum Series - http://www.amazon.com/SeaSonic-Platinum-SS-860XP2-Power-Supply/dp/B00608MP5E/ref=sr_1_3?s=pc&ie=UTF8&qid=1393746274&sr=1-3. You might be able to find a fanless power supply but I'm not sure if they make them in that capacity.
https://linustechtips.com/topic/122477-psu-help/#findComment-1629630
http://www.amazon.com/Corsair-Series-80PLUS-Gold-Certified-Supply/dp/B00EB7UIZU/ref=sr_1_3?ie=UTF8&qid=1393747196&sr=8-3&keywords=rm850
What do you need that many watts for? You might be able to get a smaller psu. (don't buy from that link just showing the PSU)
https://linustechtips.com/topic/122477-psu-help/#findComment-1629670
What are your specs of your system you planning to run? Do you plan to crossfire/sli in the future?
Hello and Welcome to LTT Forum!
If you are a new member, please read the rules located in "Forum News and Info". Thanks!  :)
Linus Tech Tips Forum Code of Conduct           FAQ           Privacy Policy & Legal Disclaimer
https://linustechtips.com/topic/122477-psu-help/#findComment-1631984
