12 minutes ago, bmx6454 said:
make sure it is using the gpu and not the igpu. can disable onboard gpu in bios, and/or make sure its the one being used in nvidia control panel.
I checked the nvidia’s control panel and it’s picking up the 1070. I’m gonna go to the bios and turn of the igpu
https://linustechtips.com/topic/1224750-cpu-problem/#findComment-13843279
