Built a new PC about a month ago now, and while I LOVE my current case, the airflow is just... not great.
Temps aren't out of control or anything, but due to the airflow it sounds like it's about to take flight I've got to push the fans so hard.
Was looking for something a bit more open in the front, have just a small triangular slit in the front for air to actually get in.
Would like to keep my current fan configuration so something that can support a 360mm rad with 3 120mm fans on it, 2 140mm fans and a 120mm fan in rear.
Would ideally like to run the rad on top in exhaust instead of using it as intake in the front. So Ideally: 360mm Rad in top, 120mm in rear and the two 140's in the front for intake.
Any suggestions would be much appreciated. MID-ATX or Full-ATX with a side panel. Doesn't need drive bays.
https://linustechtips.com/topic/1224366-seeking-high-airflow-case/
26 minutes ago, Elgorian said:
That one was toward the top of my list, just wish the fans were visible in the front.
Get RGB fans, as is at stock the Meshify needs more fans anyways.
Other good options with RGb fans include the Corsair 220T Airflow, Phanteks P400A and P500A, and the Cooler Master TD500 Mesh.
AMD Motherboard Tier List  GPU Cooling Tier List  PSU Tier List  A Dive Into Custom Keyboards & Mechanical Switches
NEWCOMERS Remember to ' Reply ' to comments in order for people to see them, this is done by clicking the arrow icon at the bottom of a comment (Quote).
My Builds:
MEGA Desk Build
Blueberry Pi  R9 3950X  Asus X470 ROG Crosshair VII Hero Wi-Fi ATX  Corsair Vengeance RGB Pro 4x16GB 3200MHz CL16  EVGA GTX 1080Ti SC Black Edition 11GB  EVGA P2 850W w/ Blue Sleeved Cables  Cryorig R1 Universal (Blue)  2x Corsair Force MP510 4TB w/ Asus Hyper m.2 V2  Corsair ML Pro Blue LED Fans  Fractal Design Meshify C TG ATX Mid Tower
Asus ROG SWIFT PG348Q 100Hz IPS G-Sync UW  Dell UltraSharp U3419W 60Hz IPS UW  Custom TOFU96  Corsair Scimitar Pro RGB
Work Rig  ThreadRipper 3970X  Asus Prime TRX40 Pro ATX  G.Skill RipjawsV 8x32GB 3200Mhz CL16  Nvidia Quadro RTX 6000 24GB  Corsair HXi 1000W  EVGA CLC 360 AIO  8x Sabrent Rocket 2TB w/ 2x Asus Hyper m.2 V2   Arctic P12 Fans  Phanteks P400A ATX Mid Tower
Plotting Machine 1  ThreadRipper 2990WX  AsRock X399 Taichi ATX  Kingston HyperX Fury 8x16GB 2666Mhz CL18   Nvidia Quadro K600 1GB  Corsair RMx 850W  EVGA CLC 360 AIO ‖ 2x Sabrent Rocket 2TB & 2x Sabrent Rocket 4TB w/ Asus Hyper m.2 V2  Arctic P12 Fans  Rosewill RSV-L4500 4U  5x Dell DS60 60-bay JBOD w/ 1.2PB of HDD Storage  HP 22U Half Rack
Plotting Machine 2  R9 3950X  Asus TUF X570-Plus Wi-Fi ATX  G.Skill RipjawsV 4x16GB 3200Mhz CL16   Nvidia Quadro K600 1GB  Corsair RM 650W  Noctua NH-D15s Chormax ‖ 4x Corsair MP600 Force 1TB W/ Asus Hyper m.2 Gen4  Arctic P14 & P12 Fans  Silverstone FARA R1 ATX Mid Tower
J.A.R.V.I.S.  R9 3900XT  Asus B550-I ROG STRIX Wi-Fi ITX  G.Skill Ripjaws V 2x16GB 3600MHz CL16  EVGA GTX 1080 SC2 iCX 8GB  Corsair SF 750W Platinum  Corsair H100i Pro AIO  Noctua NF-A12x15 Chromax Fans  FormD T1 SFF ITX Case
LG 75UM8070PUA 4K UHD 120Hz IPS HDR TV  Corsair K63 Cherry MX Red Special Edition Wireless  Corsair Ironclaw RGB Wireless
Archive Server  R3 2200G  Asus B450-I ROG STRIX Wi-Fi ITX  Corsair Vengeance RGB Pro 2x8GB 3200MHz CL16 White  Vega Integrated Graphics  EVGA P2 750W  Prism Wraith Cooler  ITX Open Bench  2x HP SAS Expander  LSI-SAS9211  220TB of HDD Storage
SFF ITX Home PC  i5-7500  MSI B250I Gaming Pro Wi-Fi AC ITX  G.Skill Ripjaws V 2x8GB 2800MHz  Intel Integrated Graphics  Seasonic SSP Flex ATX 300W PSU  Cryorig C7  Velka 3 rev 1.2 SFF ITX Case (Grey)
Laptop  Dell XPS13 2-in-1 7390 (2020)  i7-1065G7  32GB 3733MHz LPDDR4x  Intel Integrated Graphics  1TB NVME M.2  UHD+ (3840 x 2400) InfinityEdge Touch Display
Keyboard Collection  GMMK Full Size  TOFU96 90%  ‖ KBD8x MKII TKL ‖ Drop CTRL High Profile TKL ‖ KBD Bella 75% ‖ GMMK Pro 75% ‖ XD84 Pro 75%  KBD67 V2 MKII 65%  KBD67Lite 65%  TOFU65 65%  KBD Blade 60%  Drop Carina 60%  Southpaw75 60% w/ Left Numpad  OLKB Preonic V3 Ortholinear ‖ CosPad XD24  ‖ KBDPad MKII
Key Cap Collection  GMK Boba Fett  GMK Red Samurai  GMK Laser CyberDeck +Novalties  GMK Arch  MaxKey B&W  Drop MT3 Camillo ‖ Matt3o MT3 /dev/tty  KBDfans Biip Torii Ext-2048  ePBT Less But Better +Novalties  EnjoyPBT Dolch  WinMix Mustard  Drop Skylight Horizon & Slate ‖ Glorious Black Aura
Mechanical Key Switch Collection  Zealios V2 65g  Zealios V2 78g ‖ Zilents V2 67g  Tealios V2 67g  C³ Kiwi ‖ C³ Tangerine  Invyr Holy Panda  Durock T1 67g  Kailh Box Thick Jades ‖ Kailh Box Royal ‖ Kailh Box Heavy Dark Yellow ‖ Kailh Box Heavy Burnt Orange  Kailh Box White  Kailh Box Red  Kailh Pro Purple  Kailh Pro Burgandy  Gateron Ink Black V2  Gateron Black  Gateron Yellow  Gateron Brown  Gateron Green  Gateron Blue ‖ Cherry MX Black ‖ Cherry MX Brown ‖ Cherry MX Red
Right, would be keeping my current fans, just moving to a different case with better airflow.
Have
3x Corsair 120LLRGB in front pulling air through radiator
2x Corsair 140LLRGB top exhaust
1x Corsair 120LLRGB rear exhaust
This is the case I'm currently running: https://www.newegg.com/black-white-corsair-carbide-series-spec-omega-rgb-atx-mid-tower/p/N82E16811139121?item=N82E16811139121&source=region&nm_mc=knc-googleadwords-pc&cm_mmc=knc-googleadwords-pc-_-pla-_-cases+(computer+cases+-+atx+form)-_-N82E16811139121&gclid=Cj0KCQjw3s_4BRDPARIsAJsyoLOhBK2P9GQulEFia8EX7ZuNEOCR9cuVKrGe7JqFztZK0WhrBEKYjdEaAhj7EALw_wcB&gclsrc=aw.ds
and while I love it cosmetically, it has awful airflow.
1 minute ago, Elgorian said:
-Snip-
The RGB will be visible through the front mesh if that was what you were wondering, I have my Mehsify fully decked out with Corsair ML fans. My favorite case I have owned to date.
My Builds:
MEGA Desk Build
Okay, cool. Pictures don't really do that part justice, just looks like solid black mesh.
Look at this image I found. Shows that you can easily see RGB fans.
MAIN PC:
CPU: AMD Ryzen™ 7 7800X3D Motherboard: Gigabyte B650 Eagle AX CPU Cooler: EVGA CLC 240 GPU: EVGA RTX 3080 FTW3 Ultra RAM: TEAMGROUP Expert T-Create 32GB (2x16GB) 6000Mhz CL30
Case: CoolerMaster TD500 Mesh PSU: Thermaltake GF1 PE 750w Storage: 1TB Western Digital Blue 3D + 1TB Crucial P1 + 1TB ADATA XPG Gammix S11 Pro + 4TB Seagate Barracuda 5400RPM OS: Windows 10 Home
Headphones: Philips SHP9500s   Keyboard: Corsair K70 RGB MK.2 Cherry MX Red Displays: Gigabyte M27Q (27" 1440p 170hz IPS), Samsung UN32EH4003FXZA (32" 768p 60hz TV)
Former parts that I've used:  Intel® Core™ i3-9100F, Intel® Core™ i9-9900k, Asus Dual OC 2080, Gigabyte Aorus Master 3080, Gigabyte Gaming OC 3080, EVGA XC3 Ultra 3080, EVGA FTW3 Ultra 3080 Ti, EVGA 3060 XC, ASRock Z390 Phantom Gaming 4-CB, Gigabyte Z390 Aorus Pro Wifi, ADATA XPG 16GB (2x8GB) 2400Mhz CL16, Corsair Vengeance 32GB (4x8GB) 3000Mhz CL15, Scythe Fuma 2, Acer XG270HU.
Here is my case, the foam is dense but the light still passes through. This picture was also taken with all the lights on in my office.
My Builds:
MEGA Desk Build
