sry for bed english its my 3 language
(all of my drivers are up to date and its not overheating)
my gpu is acting up, when i play most games its all good, but when i try to play minecraft im geting very low fps and my gpu`s clock speed is about 600 insted of  1366.
what can i do?
https://linustechtips.com/topic/1224111-help/
What "very low fps"
Rest of specs?
Temps?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1224111-help/#findComment-13838092
10 hours ago, tzur4444 said:
yzen 5 2400g
still does not say a whole lot.
what "low fps"
Build Log:
https://linustechtips.com/topic/1224111-help/#findComment-13838112
30 fps some time 40
make sure you do not have a frame limiter or what ever it's called ( dont play minecraft that much).
set the power limit to max.
ddu ( display driver uninstaller) the drivers.
what b450 board?
Build Log:
https://linustechtips.com/topic/1224111-help/#findComment-13838120
what b450 board?
b450m ds3h
and i dont know how to set the power limit to max
https://linustechtips.com/topic/1224111-help/#findComment-13838125
set the power plan to maximum. as for the gpu/ apu, use msi after burner.
Build Log:
https://linustechtips.com/topic/1224111-help/#findComment-13838139
