Hello, this is my first time building a pc, ive RTFM and following a ton of guides. Ive assembled my pc, and it wont boot. Shows no LED indicators or anything, only LED's that show are on my graphics card near the supplementary power connectors and near the cpu (only when the cpu power isnt plugged in) other than those things the pc shows no sign of getting power. Ive replaced the power supply thinking it may be it, as it didnt even spin up. But ive tested it with the new one, and it still doesnt boot. Does this mean my motherboard is dead?
https://linustechtips.com/topic/1223483-new-pc-build-problems/
Welcome to the forums. Please post a list of your full specs.
Main Desktop: CPU - i9-14900k | Mobo - Gigabyte Z790 Aorus Elite AX | GPU - PNY Gaming OC RTX 5080 16GB RAM - Corsair Vengeance Pro RGB 64GB 6400mhz | AIO - Arctic Liquid Freezer III 360mm | PSU - Corsair RM1000X | Case - Hyte Y40 - White | Storage - Samsung 980 Pro 1TB Nvme /  Sabrent Rocket 4 Plus 4TB Nvme / Samsung 970 EVO Plus 2TB Nvme / Samsung 870 EVO 4TB SSD / Samsung 870 QVO 2TB SSD/ Samsung 860 EVO 500GB SSD|
Phone: Samsung Galaxy S26 Ultra - Black 256GB |
https://linustechtips.com/topic/1223483-new-pc-build-problems/#findComment-13833477
We definitely are going to need more info to be able to help. Also, many PSU's have "silent mode" where the fan doesn't turn on until the PSU is under load, so depending on the PSU, that may be totally normal behavior.
https://linustechtips.com/topic/1223483-new-pc-build-problems/#findComment-13833492
CPU/Cooler: Ryzen 7 3700X 4.2GHz Cooled by Fractal Design Celsius S36 Blackout
RAM: G.SKILL Trident Z Neo 32GB 4x8 3600Mhz
Motherboard: ASUS ROG Strix B550-E Gaming AMD AM4
GPU: ASUS ROG Strix GeForce RTX 2080 Ti
Storage: 1TB Samsung 970 EVO Plus / 2x2TB Seagate Barracuda
Case: Fractal Design Meshify S2 Black Dark Tint Tempered Glass
Power supply: EVGA SuperNOVA 850 GA (Swapped to)  Corsair RM850 80+GOLD
I've swapped out the powersupply, ive tried just getting the motherboard to get power, so it was the only thing powered by the PSU.
Ive tried powering the whole motherboard (cpu and board power) only and nothing else.
Only time i get any sign of "power" is when the GPU is hooked up and the cpu is disconneted. The LEDS on both light up with RED(CPU) and/or Flashing White/Red (GPU)
https://linustechtips.com/topic/1223483-new-pc-build-problems/#findComment-13833500
