Hello all,
I really need to replace my hdd's. They've lived out their expected life span plus some, with some abuse along the way. So my question is.... How do I go about switching out my raid 5(3 hdd's) with a new SINGLE drive ? I have backed up all of my pics, music, movies, and games, now i just need to know how to fix this thing!!! I'm still a noob when it comes to working on my pc so any and all help is appreciated because the only things i've done are swap out my gpu and add more RAM.... and thats... well... easy mode so.. ya.
Thanks in advance!
So you currently have a 3-drive RAID 5 array, and you'd like to replace this array with a single HDD?
Okay... that's quite simple. Copy the contents of the RAID 5 array onto the single larger HDD... and then you're done. Can you be a little bit more explicit in what you're asking for?
For Sale: Meraki Bundle
iPhone Xr 128 GB Product Red - HP Spectre x360 13" (i5 - 8 GB RAM - 256 GB SSD) - HP ZBook 15v G5 15" (i7-8850H - 16 GB RAM - 512 GB SSD - NVIDIA Quadro P600)
This.
Also, if you do decide to go with parity RAID again, be sure to get NAS drives. Consumer drives are bad for Parity RAID.
But a copy/paste is basically what you need. Then just delete the RAID5 volume in Disk Manager and rock on.
† Christian Member †
For my pertinent links to guides, reviews, and anything similar, go here, and look under the spoiler labeled such. A brief history of Unix and it's relation to OS X by Builder.
I was expecting something much more complex being asked...
  • 1 month later...
If the array is still alive and kicking and isnt a boot drive just pop the new drive in your system and copy and past the files in windows.
Thanks, so I can add the new drive even with raid enabled ? then just copy, paste, disable raid and I'm done ?
yes
You technically don't have to change the SATA controller from RAID to AHCI mode, you can just delete the RAID volume and leave the controller in RAID mode.  Won't hurt anything.
Desktop: Intel Core i7-6700K, ASUS Z170-A, ASUS STRIX GTX 1080 Ti, 16GB DDR4 RAM, 512 GB Samsund 840 Pro, Seasonic X series 650W PSU, Fractal Design Define R4, 2x5TB HDD
Hypervisor 1: Intel Xeon E5-2630L, ASRock EPC612D8, 16GB DDR4 ECC RAM, Intel RT3WB080 8-port RAID controller plus expansion card, Norco RPC-4020 case, 20x2TB WD Red HDD
Other spare hypervisors: Dell Poweredge 2950, HP Proliant DL380 G5
Laptops: ThinkPads, lots of ThinkPads
