I'm using r5 3600 and 5700 xt. At 1440p I'm not even getting good frames in rocket League and my graphics utilisation is jumping around from 50% to 1%. I have set my ram to its rated 3200mhz in the bios and am using a seasonic gx750 750 watt power supply. Any help would really be appreciated.
https://linustechtips.com/topic/1222821-performance-issues-please-help/
what motherboard do you have?
do you have 2 sticks of ram and are they in slots 2 and 4? does task manager show you have the ram at 3200?
do you have the latest chipset drivers, video drivers and bios?
can you monitor the temperatures of the cpu and gpu?
what about the cpu utilization ? also temps for both
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
My GPU temps were fine, below 60c how do I check my CPU temps
Yeah I have 2 sticks in 2 and 4 and they show 3200 in tm I installed drivers when I built it a month ago but this is my first build. Oh in task manager it says my GPU video encode is at 99-100%. Does this mean it's trying to stream?
13 minutes ago, boggy77 said:
yeah looks like something is using your gpu for saving video. take a look in the processes tab and see what process uses your gpu
Ok after my pc restarted from updated my graphics drivers, the video encoding has gone down to 40% and rocket League performance is good. Do you know what that process is in tm?
https://www.howtogeek.com/273180/how-to-disable-windows-10s-game-dvr-and-game-bar/
it's windows crap that you don't need. disable it
Ok thanks a lot for the help:) I guess things like that are part of the reason why people like Linux
