I just moved in with 3 of my roommates and we all have pcs. And we're all hardwired into the modem and im the only one out of the 4 of us who is getting network problems, randomly ingame ill just lose connection to the internet and then it will kick back in 10 to 15 secs later. I was wondering maybe its my network card or my Ethernet cord, wanted to get another persons opinion on the situation.
https://linustechtips.com/topic/1222576-need-help-identifying-the-problem/
Try to get a usb WiFi adapter? If you can’t then idk
1 minute ago, Heliian said:
Go into the modem settings to check if there's a restriction on your connection like a bandwidth limiter or traffic priority list.  If that's all good, then yes, it's you.
Hmmmmm Also it could be your firewall as well thanks for the reply Heliian
