Hello, I started working regularly in a pc service shop. And I got 2 ssd, One SSD is kingston 128gb which only shows 4mb when I try to install windows 10 on any laptop or computer it's quite new tho.. The second ssd is silicon power 512gb, which can't create a partition and says it's "locked".
Can anyone help me and find a fix or a software tool which can help me?
Thanks
https://linustechtips.com/topic/1222168-ssd-help-fix/
Thanks
Sounds like the Kingston has created a recovery partition; were all the partitions removed when you installed Windows?
The Silicon Power one could be encrypted to the machine it was removed from.
**I frequently edit any posts you may quote; please check for anything I 'may' have amended.**
Current PC spec. in my profile.
Can I realistically call myself a gamer, if I only play ONE, twenty year old game...?
Did you test boot it, before you built in into the case?
WHY NOT...?!
https://linustechtips.com/topic/1222168-ssd-help-fix/#findComment-13822424
13 minutes ago, Lelouch Lamperouge said:
If Disk 0 is the Kingston, that looks about right; Disk 1... that red arrow icon looks ominous.
WHY NOT...?!
https://linustechtips.com/topic/1222168-ssd-help-fix/#findComment-13822486
12 hours ago, NewMaxx said:
Check firmware on the A400. It uses the S11 which also has some tools available for it.
Thanks,
But does anyone know how can I unlock Silicon Power? It happend after copying the windows on it and installing it on a new machine. It's a brand new ssd 521gb
https://linustechtips.com/topic/1222168-ssd-help-fix/#findComment-13824587
