Help
Go to solution Solved by Sauron,
4 minutes ago, ALBas126 said:
this is the video I used
Why did you call tkinter() (which does not exist) instead of Tk() as seen in the tutorial?
I was trying to get back into coding and I was watching and following a long a yt tutorial what is the problem with this code?
from tkinter import *
root = tkinter()
# Creating a label widget
myLabel = label(root, text="Hello World!")
# Shoving it to the top screen
myLabel.pack()
root.mainloop()
the error I got said:
Traceback (most recent call last):
  File "gui toturial.py", line 3, in <module>
    root = tkinter()
NameError: name 'tkinter' is not defined
***Repl Closed***
https://linustechtips.com/topic/1221977-help/
