Hello this is my first high budget, for my country, system and I'm pretty curious if my temps are right or not.
CPU: Ryzen 7 3800X at 4.1Ghz 1.1V
Cooler: Corsair H115i RGB PRO XT (280mm)
Ambient Temp of the Room: 30-31C
When on Load (Cinebench): https://prnt.sc/th2sm4
On Idle: https://prnt.sc/th2t3k
Edited by Originoodle
added photos
https://linustechtips.com/topic/1221663-is-my-liquid-temps-normal/
1 minute ago, Jae Tee said:
Can you list them?
if You mean all parts
GPU: Gigabyte 2070S
Mobo: MSI X570 MPG Gaming Edge
Storage: WD Black 2TB m.2 ssd
Sound Card: Soundblaster Z
3x Corsair AF140 - Exhaust (2 on top, 1 on back)
No, can you list out right the temps?
At me or quote me, I want to hear your opinion.
Hopefully anything I say is factually correct. Sorry for any mistakes in advanced.
1 minute ago, Originoodle said:
Thank you very much, I am just baffled that water temps don't go high at all. I'm using water cooling for the first time
yeah over time it will heat up,  but not nearly as hot as the components that its cooling. It's all about thermal dynamics or some thing like that.
