I have recently set out to build a PC. Everything has gone fine, but had serious problems sourcing a PSU. So I opted to buy a second-hand PSU off of eBay. I made sure to buy a PSU that was endorsed by PSU tier list out on the net. I seem to have this problem (see sound file attached) during the first 20 mins the sound is very audible and after you can't hear it unless you hold your ear close to the PSU. At first I thought it was feedback, and thought the motherboard was maybe the issue but now I'm quite sure the noise is coming from the PSU. Can you advise troubleshooting steps or whether I should be concerned at this? Just weighing up does it need returning or is it normal. Hearing PSU whine videos on YouTube it doesn't quite sound like that.
SPECS
  • Case: SaharaGaming P35
  • PSU: Corsair TX750W
  • CPU Cooler: Arctic Freezer 34 eSports DUO
  • Drives 465GB Hitachi HGST HTS545050A7E680 (SATA )  223GB SanDisk SDSSDA240G (SATA (SSD)) 465GB Hitachi HGST HTS725050A7E630 (SATA ) 238GB SAMSUNG SSD PM871a M.2 2280 256GB (SATA (SSD))
  • Processor: AMD Ryzen 5 3600 6-Core Processor               (12 CPUs), ~3.6GHz
  • GPU: 4095MB NVIDIA GeForce GTX 1050 Ti (NVIDIA)
  • Motherboard: TOMAHAWK MAX (MS-7C02) (AM4)
  • RAM: Corsair 16GB Vengeance 3200
static_noise.wav
https://linustechtips.com/topic/1221529-psu-noise-help/
this could be caused by your drives, otherwise It's coil whine, common on some PSUs
Main PC [The Rig of Theseus]:
CPU: i5-8600K @ 5.0 GHz | GPU: GTX 1660 | RAM: 16 GB DDR4 3000 MHz | Case: Lian Li PC-O11 Dynamic | PSU: Corsair RM 650i | SSD: Corsair MP510 480 GB |  HDD: 2x 6 TB WD Red| Motherboard: Gigabyte Z390 Aorus Pro | OS: Windows 11 Pro for Workstations
Secondary PC [Why did I bother]:
CPU: AMD Athlon 3000G | GPU: Vega 3 iGPU | RAM: 8 GB DDR4 3000 MHz | Case: Corsair 88R | PSU: Corsair VS 650 | SSD: WD Green M.2 SATA 120 GB | Motherboard: MSI A320M-A PRO MAX | OS: Windows 11 Pro for Workstations
Server [Solution in search of a problem]:
Model: HP DL360e Gen8 | CPU: 1x Xeon E5-2430L v1 | RAM: 12 GB DDR3 1066 MHz | SSD: Kingston A400 120 GB | OS: VMware ESXi 7
Server 2 electric boogaloo [A waste of electricity]:
Model: intel NUC NUC5CPYH | CPU: Celeron N3050 | RAM: 2GB DDR3L 1600 MHz | SSD: Kingston UV400 120 GB | OS: Debian Bullseye
Laptop:
Model: ThinkBook 14 Gen 2 AMD | CPU: Ryzen 7 4700U | RAM: 16 GB DDR4 3200 MHz | OS: Windows 11 Pro
Photography:
Cameras:
Full Frame digital: Sony α7
APS-C digital: Sony α100
Medium Format Film: Kodak Junior SIX-20
35mm Film:
Lenses:
Sony SAL-1870 18-70mm ƒ/3.5-5.6
Sony SAL-75300 75-300mm ƒ/4.5-5.6
Meike MK-50mm ƒ/1.7
PSA: No, I didn't waste all that money on computers, (except the main one) my server cost $40, the intel NUC was my old PC (although then it had 8GB of ram, I gave the bigger stick of ram to a person who really needed it), my laptop is used and the second PC is really cheap.
I like tinkering with computers and have a personal hatred towards phones and everything they represent (I daily drive an iPhone 7, or a 6, depends on which one works that day)
https://linustechtips.com/topic/1221529-psu-noise-help/#findComment-13817044
