Me and my friend decided to build a pc but when we built it, it wouldn't bot and Vega, dram, boot lights on the side of the mother board and we don't know what to do
Ryzen 5 3600, corsair vengeance 16gb(2×8), mis x470
Edit:it was the gpu, 980ti... it blew up
https://linustechtips.com/topic/1221472-help/
Yea if you don't have a gpu you won't display an image. The 3600 lacks an i-gpu.
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1221472-help/#findComment-13816326
Yeah, I've been having the same problems with my mis x470 too. Strange.
https://linustechtips.com/topic/1221472-help/#findComment-13816349
