Hey guys, I want to ask, what do you guys think is better, 120gb Samsung 840 EVO + copy of windows 7 HP or 250gb Samsung 840 Evo and transfer the data from my current HDD to SSD? Note: I should be able to trim down the data to below 200gb if going with 2nd option.
ASUS ROG G75VX
Intel i7-3630QM 2.4GHz/3.4GHz Turbo | Nvidia GeForce 670MX 3GB OCed to 736MHz | 750GB HDD | Windows 8.1 | 24 GB 1600MHz RAM | Razer Goliathus Medium | Logitech G400s | Razer Kraken/ JBL J22 | Corsair Vengeance K70 Cherry MX blue
https://linustechtips.com/topic/122142-need-some-help-choosing/
Is it an option to keep your HHD and install an SSD? Even if you put all 200GB of data into your 250GB SSD, 50GB fills up pretty fast (depending on what you're planning to do).
| CPUAMD FX-6350 4.2Ghz | MotherboardGigabyte: GA-78LMT-USB3 | RAM16 GBytes DDR3 | GPUMSI AMD Radeon R9 290 Twin Frozr IV OC Edition | PSU: Corsair 650W Modular +Gold Certified | Storage: 2 TB HDD |
https://linustechtips.com/topic/122142-need-some-help-choosing/#findComment-1625735
My laptop has 2 HDD bays, I can keep both drives, its only temporary.
ASUS ROG G75VX
https://linustechtips.com/topic/122142-need-some-help-choosing/#findComment-1625757
If it's only temporary then I would still go for 250GB, it's more useful in the long term.
https://linustechtips.com/topic/122142-need-some-help-choosing/#findComment-1625762
Thinking about it, I should have created a poll...
ASUS ROG G75VX
https://linustechtips.com/topic/122142-need-some-help-choosing/#findComment-1625769
if you wanna throw money away on temp stuff then go for the best of the best ahaha!
huh? What do you mean throw away money on temp stuff?
ASUS ROG G75VX
https://linustechtips.com/topic/122142-need-some-help-choosing/#findComment-1625837
