Budget (including currency):$1500
Country: US
Games, programs or workloads that it will be used for: iRacing, Photoshop Elements, Autodesk, Xplane 11, forza horizon, and modern warfare.
Other details Hi everyone, so I made some progress on computer build, I purchased a Corsair Carbide 678C in white low noise case and will receive it soon and now I'm wanting to get the power supply. What is the recommended graphics card that is not very loud when under load and 8gb in graphics memory? What PSU is reliable and how much wattage would I need to power a amd ryzen 7 3700x? I'm also looking at buying the Gigabyte B550 Aorus Master ATX mobo. I would like to have the system ram to have either 16 or 32gb and atleast 1 SSD no hard drives. I'm going for a quiet system which means no liquid cooling, and what type of 140mm fans should i look for to put into a quiet system even under load? This is going in a small bedroom,  my ears are sensitive to loud noises. Thanks for helping. Also what type of CPU cooler would be compatible with the case I bought and keep it quiet, not expecting to be perfectly silent just very low noise. Thanks again everyone.
https://linustechtips.com/topic/1220932-first-pc-build/
Well, the mobo might not be the best choice (at least for the 279.99$ in PCpartPicker), for that price I would consider a X570 mobo, but as it has an extra fan, I would just go for a lower B550 mobo like the B550 tomahawk. For the cooler, I would go for a be quiet! Dark Rock Pro 4, as it is very quiet while being a great cooler. The GPU is, while idling, silent as the fans are off, during games they will produce some noise, but there is no way around it. I would consider some 140mm be quiet pure wings 2.
This is the build I would make (later you can upgrade both the storage and the RAM):
https://pcpartpicker.com/list/khWhHB
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13812057
https://pcpartpicker.com/list/gj7QJb
Still has room for better motherboard, storage or GPU! :D
Zen-III-X8-5900X (Gamestation 5)
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Ryzen 5 3600, 6-cores, 12-threads, 4.2/4.2GHz, 35,3MB cache (T.S.M.C. 7nm FinFET) / CPU: AMD Ryzen 9 5900X, 12(8)-cores, 24(16)-threads, 4.5/4.8GHz, 70.5MB(68,35MB) cache (T.S.M.C. 7nm FinFET) / Display: HP 24" L2445w (64Hz OC) 1920x1200 / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: ASUS Radeon RX 6600 XT DUAL OC RDNA2 32CUs @2.6GHz 10.6 TFLOPS (T.S.M.C. 7nm FinFET) R.ID (NimeZ drivers) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: ASRock B450M Pro4, Socket-AM4 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W / RAM A1 & B1: G.SKILL DDR4-3600MHz CL18-20-21-39-60-1T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: HyperX DDR4-3600MHz CL16-18-19-37-85-1T "SK Hynix 8Gbit CJR" (2x16GB) / Operating System: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Western Digital My Passport 2.5" 2TB HDD / Storage 4: Western Digital Elements Desktop 2TB HDD / Storage 5: Kingston A2000 1TB M.2 NVME SSD / Wi-fi & Bluetooth: ASUS PCE-AC55BT Wireless Adapter (Intel)
 Lake-V-X6-10600 (Gaming PC)
R23 score MC: 9190pts | R23 score SC: 1302pts
R20 score MC: 3529cb | R20 score SC: 506cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: Intel Core i5-10600(ASUS Performance Enhancement), 6-cores, 12-threads, 4.4/4.8GHz, 13,7MB cache (Intel 14nm++ FinFET) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: Gigabyte Radeon RX Vega 56 Gaming OC GCN5 56CUs @1.7GHz 12.19 TFLOPS (Samsung 14nm FinFET) R.ID (NimeZ drivers) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: ASUS PRIME B460 PLUS, Socket-LGA1200 (SAM enabled) / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W / RAM A1 & B1: HyperX DDR4-2666MHz CL13-15-15-30-45-2T "Samsung 8Gbit C-Die" (2x8GB) / RAM A2 & B2: Juhor DDR4-3200MHz CL16-20-20-38-72-2T "SK Hynix 8Gbit MFR" (2x16GB) / Operating System: Windows 10 Home / Sound: Zombee Z300 / Storage 1 & 2: Samsung 850 EVO 500GB SSD / Storage 3: Seagate® Barracuda 2TB HDD / Storage 4: Seagate® Desktop 2TB SSHD / Storage 5: Crucial P1 1000GB M.2 SSD/ Storage 6: Western Digital WD7500BPKX 2.5" HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter (Qualcomm Atheros)
Vishera-X8-9370 | R20 score MC: 1476cb
Case: Cooler Master HAF XB Evo Black / Case Fan(s) Front: Noctua NF-A14 ULN 140mm Premium Fans / Case Fan(s) Rear: Corsair Air Series AF120 Quiet Edition (red) / Case Fan(s) Side: Noctua NF-A6x25 FLX 60mm Premium Fan / Case Fan VRM: SUNON MagLev KDE1209PTV3 92mm / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: Cooler Master Hyper 212 Evo / CPU: AMD FX-8370 (Base: @4.4GHz | Turbo: @4.7GHz) Black Edition Eight-Core (Global Foundries 32nm) / Display: ASUS 24" LED VN247H (67Hz OC) 1920x1080p / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / GPU: Gigabyte Radeon RX Vega 56 Gaming OC @1501MHz (Samsung 14nm FinFET) / Keyboard: Logitech Desktop K120 (Nordic) / Motherboard: MSI 970 GAMING, Socket-AM3+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 850W PSU / RAM 1, 2, 3 & 4: Corsair Vengeance DDR3-1866MHz CL8-10-10-28-37-2T (4x4GB) 16.38GB / Operating System 1: Windows 10 Home / Sound: Zombee Z300 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Seagate® Barracuda 2TB HDD / Storage 3: Seagate® Desktop 2TB SSHD / Wi-fi: TP-Link TL-WN951N 11n Wireless Adapter
Godavari-X4-880K | R20 score MC: 810cb
Case: Medion Micro-ATX Case / Case Fan Front: SUNON MagLev PF70251VX-Q000-S99 70mm / Case Fan Rear: Fanner Tech(Shen Zhen)Co.,LTD. 80mm (Purple) / Controller: Sony Dualshock 4 Wireless (DS4Windows) / Cooler: AMD Near-silent 95w Thermal Solution / Cooler: AMD Near-silent 125w Thermal Solution / CPU: AMD Athlon X4 860K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / CPU: AMD Athlon X4 880K Black Edition Elite Quad-Core (T.S.M.C. 28nm) / Display: HP 19" Flat Panel L1940 (75Hz) 1280x1024 / GPU: EVGA GeForce GTX 960 SuperSC 2GB (T.S.M.C. 28nm) / GPU: MSI GeForce GTX 970 4GD5 OC "Afterburner" @1450MHz (T.S.M.C. 28nm) / Keyboard: HP KB-0316 PS/2 (Nordic) / Motherboard: MSI A78M-E45 V2, Socket-FM2+ / Mouse: Razer Abyssus 2014 / PCI-E: ASRock USB 3.1/A+C (PCI Express x4) / PSU: EVGA SuperNOVA G2, 550W PSU / RAM 1, 2, 3 & 4: SK hynix DDR3-1866MHz CL9-10-11-27-40 (4x4GB) 16.38GB / Operating System 1: Ubuntu Gnome 16.04 LTS (Xenial Xerus) / Operating System 2: Windows 10 Home / Sound 1: Zombee Z500 / Sound 2: Logitech Stereo Speakers S-150 / Storage 1: Samsung 850 EVO 500GB SSD (x2) / Storage 2: Western Digital My Passport 2.5" 2TB HDD / Storage 3: Western Digital Elements Desktop 2TB HDD / Wi-fi: TP-Link TL-WN851N 11n Wireless Adapter
Acer Aspire 7738G custom (changed CPU, GPU & Storage)
CPU: Intel Core 2 Duo P8600, 2-cores, 2-threads, 2.4GHz, 3MB cache (Intel 45nm) / GPU: ATi Radeon HD 4570 515MB DDR2 (T.S.M.C. 55nm) / RAM: DDR2-1066MHz CL7-7-7-20-1T (2x2GB) / Operating System: Windows 10 Home / Storage: Crucial BX500 480GB 3D NAND SATA 2.5" SSD
Complete portable device SoC history:
Apple A4 - Apple iPod touch (4th generation)
Apple A5 - Apple iPod touch (5th generation)
Apple A9 - Apple iPhone 6s Plus
HiSilicon Kirin 810 (T.S.M.C. 7nm) - Huawei P40 Lite / Huawei nova 7i
Mediatek Dimensity 700 (T.S.M.C 7nm) - Cherry Mobile Aqua S10 Pro 5G
Mediatek MT2601 (T.S.M.C 28nm) - TicWatch E
Mediatek MT6580 (T.S.M.C 28nm) - TECNO Spark 2 (1GB RAM)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (orange)
Mediatek MT6592M (T.S.M.C 28nm) - my|phone my32 (yellow)
Mediatek MT6735 (T.S.M.C 28nm) - HMD Nokia 3 Dual SIM
Mediatek MT6737 (T.S.M.C 28nm) - Cherry Mobile Flare S6
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (blue)
Mediatek MT6739 (T.S.M.C 28nm) - my|phone myX8 (gold)
Mediatek MT6750 (T.S.M.C 28nm) - honor 6C Pro / honor V9 Play
Mediatek MT6765 (T.S.M.C 12nm) - TECNO Pouvoir 3 Plus
Mediatek MT6797D (T.S.M.C 20nm) - my|phone Brown Tab 1
Qualcomm MSM8926 (T.S.M.C. 28nm) - Microsoft Lumia 640 LTE
Qualcomm MSM8974AA (T.S.M.C. 28nm) - Blackberry Passport
Qualcomm SDM710 (Samsung 10nm) - Oppo Realme 3 Pro
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813262
Noctua cooler and fans if you care about low noise. Be Quiet is a good runner up, but they still don't beat Noctua, in both noise and cooling performance. I will say Be Quiet has a larger line of good looking products. The Noctua chromax.black line is sick, but not all of their products are available in that line.
The key to quiet, regardless, is low fan speeds. The lower you can spin the fans and still cool everything, the more quiet your system will be. That means 1) having a case with good air flow and 2) having powerful fans that push a ton of air. Ironically, "quiet" cases work against you on the first point, as the materials used to silence the case generally also restrict air flow. It might be a little bit of a trade off there, i.e. you actually end up with more fan noise, but hopefully not so much that it overwhelms the noise dampening.
CPU: AMD Ryzen 9 9950X3D · Cooler: Noctua NH-D15S Chromax.black · Motherboard: Gigabyte Auros X670 Elite AX · RAM: G.Skill Flare X5 64GB (2 x 32GB) DDR5 6000MHz CL30 · Graphics Card: Zotac NVIDIA GeForce RTX 4070 Super Twin Edge OC 12GB · Boot Drive: 1TB XPG Gammix S70 Blade NVMe SSD · Game Drive: 2TB WD SN850X NVMe SSD · PSU: Seasonic Focus GX V3 1000W 80+ Gold · Case: Fractal Design North Mesh · Monitor: MSI Optix MAG342CQR 34” UWQHD 3440x1440 144Hz · Keyboard: EPOMAKER x Aula F99 Wireless Mechanical Keyboard · Mouse: Logitech G309 Lightspeed Wireless Gaming Mouse
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813450
14 hours ago, woody30 said:
ok thank you for taking time to pick the parts. What do you think about the corsair rm850x power supply as an option? I just want a PSU thats going to be reliable and fairly quiet even under load. @filiboss123
Despite being more expensive, it is a good choice!
I agree, Noctua does great cooler ehich are in fact very quiet, but even in the cromax lineup, they are a bit less appealing in what comes to the look. I think the dark rock pro 4 is the best choice, quiet, efficient, and good looking (after all, you will live with it for several years with it beside you).
The choice is yours, the difference is marginal!
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813909
@Nena Trinity that buid does not correspond to his budget... and you have not read his requirements. He said that he already had a case, wanted no HDD, and wanted a quiet desktop (something that both the hdd and the stock cpu cooler are bad at!). Next time check what the person wants, do not give them a generic build!
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813929
Most drives I have had has not really made any notable sounds...
https://pcpartpicker.com/list/pssdRk
Silent enough? He clearly didn't want a AIO due to pump... :I
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813944
Ok, now it is better, however you still have worse RAM, Cooler and MOBO. All that for an 2Tb ssd... (something that can easily added later...)
You still did not take notice of the fact that @woody30 already has a case.
At the expense
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813951
At the expense
Could use that for faster RAM or board then. :D
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813958
I actually really like the look of the chromax.black line, especially when you pair it with the additional accessories. Granted, that adds to the cost, but damn if it doesn't look good in my black and white (mostly) build with the white vibration pads and white cooler cover.
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813972
I admit that looks good! I just think it is not worth it personally! They are both a great choice. And I must say, nice build!
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13813978
1 hour ago, filiboss123 said:
Anyway, I still believe my build would be the best for you @woody30!
Ya sure its enough storage? Modern Warfare alone takes over 100GB... :I
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13814173
I said it once and I will say it again. The storage is easily upgraded!!
My build has a better mobo (much more recent and way better looking) and a way better cooler that is way more efficient and much quieter, not to mention the RAM, that is 3200MHz intead of 3600MHz and has no heatsink what so ever!
Storage is not to expensive and it is one of the easiest components to add to a build!!!
He can get around with 500Gb for a while, as soon as he manages to buy another SSD, it is easy to install!! Just plug and play!
Furthermore my build has an NVME SSD that is way faster than Sata SSD's!
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13814819
@filiboss123 I've decided to go with your motherboard that you've chosen me, but have a question about the CPU. I noticed there is a difference in TDP for the same model. One says 65W TDP and the other says 105W TDP for the Ryzen 7 3700x, which one do I need to get? Thanks again for helping. @Linus
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13823571
If I am not mistaken the ryzen 7 3700X is a 65W CPU, as the 3800x is the one that has 105W TDP.
https://www.amd.com/pt/products/cpu/amd-ryzen-7-3700x
Depending on the price it might not be worth the upgrade... I would say that if the difference is more than 50$, it is not worth it.
Then there is the fact that the TDP increase may cause a need to upgrade your psu, further increasing tge price of your build.
https://linustechtips.com/topic/1220932-first-pc-build/#findComment-13845853
