Hi, I'm looking to buy a new laptop for college which I'm starting in about a month. I have looked extensively through many sites, videos, and forums, but can't seem to find a perfect one. It needs to be $1100 at most (bonus points if on sale or has deal). This laptop will be used for school work, coding and possibly for work. (This will NOT be used for gaming). Any and all reccomdations, advice, or ideas will be a big help! Thank you!
My preferences for a laptop are (but not limited to):
• 15 inch screen
• Slim build (not bulky)
• Strong CPU
• Good amount of SSD (with possible additional HDD)
• Not touch screen
• Long battery life
https://linustechtips.com/topic/1220702-college-laptop-help/
• 15 inch screen
• Strong CPU
• Not touch screen
• Long battery life
I believe alex did a review on some laptops which you may be after on shortcircuit, might want to check it out if its wverything you're after. Other than that, I don't use laptops anymore so I can't give you my own opinion on whats a decent laptop with specs like that.
https://linustechtips.com/topic/1220702-college-laptop-help/#findComment-13810041
10 minutes ago, Kolgrim17 said:
-HP Envy x360 with R5 4500U or better
-Lenovo Ideapad 5 15 with 4500U or  better
-Asus Zephyrus G14 with 4600H or 4800H (if within budget)
If you want the best CPU performance, ryzen 4000 is the obvious choice. The U series will probably suit you more as the H series are often paired with discrete GPUs in more 'gamery' and less refined designs, although they will be more powerful.
Edit:  Also, Lenovo Flex 5 14
PC
Ryzen 5 2600 Stock
Sapphire Nitro+ Special Edition Radeon RX580 8GB (Would Recommend)
Gigabyte B450M DS3H (Don't recommend)
Hyper 212 RGB Black Edition
Corsair Vengeance LPX 2x8GB DDR4 3000MHz CL15
Phanteks P300 (Would Recommend)
Kingston A400 240GB SSD
Seagate BarraCuda 1TB HDD
Corsair CX550M 550W  80+ Bronze
Deepcool FH-10 Fan Hub
3x BeQuiet Pure Wings 2
https://uk.pcpartpicker.com/user/marmour/saved/QTY3ZL
Peripherals
LG 24MK400H
Logitech G413 Carbon
Logitech G305 (AAA Adaptor - 10g reduction) (Would recommend)
Logitech Z150
HyperX Cloud II (Would recommend)
Moto G5 Plus (Webcam)
Phone
Pixel 3A XL (Would recommend)
*Useful Link* PSU Tier List: https://linustechtips.com/main/topic/1116640-psucultists-psu-tier-list/
https://linustechtips.com/topic/1220702-college-laptop-help/#findComment-13810047
