Hi i have two xeon 5640 and they runn at like 80c when doind light gaming and some multitasking but my gpu is only at 60c
https://www.ebay.com/itm/Intel-Xeon-CPU-Cooler-Heatsink-Fan-for-Quad-Core-54XX-CPU-Socket-J-LGA771-New-/131310325400?hash=item1e92b48e98:m:mT1rxCVA3kOPonyfhWriMtw
I think i have that cooler is 80c ok for xeons
https://linustechtips.com/topic/1220656-cpu-way-hotter-than-gpu/
8 minutes ago, Ihobonu3 said:
is 80c ok for xeons
Yes.
Phone: Pixel 3a (Purple-ish).
Build Log:
Cpu normally does get a little bit hotter than GPU unless you have a great cooling on CPU. But 80c seems fine. My old xeon would do the same
CPU - I9 10900 | CPU Cooler - Corsair Hydro Series H100x AIO | Motherboard -  Aorus B460 PRO AC | RAM -G.SKILL Ripjaw V series 4x8GB 2666MHZ | Graphics Card - Gigabyte RTX 3070  | Power Supply - Cooler Master 650w  | Storage -  Working on a new Spicy
Operating System - Windows 10 Pro
