11 minutes ago, highrusher said:
turn it on it starts beeping
What type of beeps?
Specs?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1220642-help-pc/#findComment-13809558
3 minutes ago, mahyar said:
is your pc an office
What does that even mean?
Build Log:
https://linustechtips.com/topic/1220642-help-pc/#findComment-13809569
Just now, mahyar said:
i mean does it have proprietary psu and motherboard?
That wont really help.
Also there are OEM's with standard atx components.
Build Log:
https://linustechtips.com/topic/1220642-help-pc/#findComment-13809575
3 minutes ago, NZgamer said:
What are the specs?
What is the exact model?
What is the exact pattern of the beeps?
Have you tried reseating the memory?
The specs are 2x512mb of ram i think, Intel core 2 vPro I dont know the exact method and yea btw after 5secs of beeping the pc starts to sound like a jet engine
Here is the pattern of the beeps:
Voice 013
https://linustechtips.com/topic/1220642-help-pc/#findComment-13809579
btw if u couldn't download this heres a link of the voice message https://voca.ro/8TGy8yXnIou
https://linustechtips.com/topic/1220642-help-pc/#findComment-13809585
3 hours ago, NZgamer said:
Well it was kind of hard to tell the beep pattern from that (it's not your fault, these beep patterns are fucking stupid)
But it could be any of these:
btw guys ty i fixed it, apparantly some of the ram sticks were bad so I switched them
https://linustechtips.com/topic/1220642-help-pc/#findComment-13809987
