I've still getting random bsod with no error code.
So far I've
-tried restarting
-using the sfc /scannow (the first time, errors showed up, but after that using it again is pointless)
- updated drivers
-reinstalled any and all programs and drivers
-reset windows 10, with a new install
-I've also tried ubisoft support at first then tried Windows 10 support.
It seems to be mainly while Im gaming on AC Odyssey that Im having weird stuttering issues and crashes/BSOD
I thought the windows 10 install would help with bsod, but apparently not.
What i do know is that, the bsod seems to tend to happen when my cpu shoots up to 90% or higher.
I would like to know, how do i test pc parts to check if something is failing? i.e. cpu, gpu, drives, anything else I cant think of at the moment.
I have an i5-7600k on z270e motherboard with a 1070 asus gpu. Fanless 600 watt seasonic psu. I have 2 NVME ssd. cpu and gpu is watercooled by 360mm rad.
I have samsung magician as well, and according to that, the drives are in good condition.
Currently, I would like to avoid replacing any parts if possible until a couple months down the line (looking to build a new pc with 4th gen ryzen and new nvida gpu)
https://linustechtips.com/topic/1220631-testing-pc-parts/
if it BSODs, there is always an error.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1220631-testing-pc-parts/#findComment-13809472
It usually says system service exception or unexpected store exception.
It doesn't say what failed. it doesnt always create a log of what happened either.
Doesn't state what failed or anything.
previously it would restart by itself, but since to me the screen just blinked blue for a second before doing that, I turned on the option to have to manually restart my pc when it gets a bsod.
Update: I've reset my windows 10, and wiped out most files, and it seems to be running better, so hoping i dont get bsod again anytime soon. but if there was a way to test each individual component , then maybe i could find out if there really is anything wrong or if something may fail in the near future
https://linustechtips.com/topic/1220631-testing-pc-parts/#findComment-13814914
