If you have more then one ram stick remove them and leave just one install. start the computer and see what happends and leave it on for awhale.
Now if the computer is fine, turn it off and try outher stick.in the same slot, keep doing that in till the problem comes back. let me know how it goes.
so we are doing is testing your ram.
Ok ok ok, I left one stick of RAM in for about 10mins and the same problem happend. But when i tried the other stick, it was fine, i could reach my desktop and everything. So im guessing that means i have a RAM problem?
Thx
Sounds like you have a big RAM issue.
Try the suspected RAM stick alone in another computer, if you have one. If similar results occur, then begin the RMA process with your RAM manufacturer.
All though i will do what you have told me to, my pc stopped working AGAIN. Could both of my RAM modules be corrupted???
