alright Im building pc and Im almost done but I have two questions,
First
What other wires go through this G connector?
I mean I dont have any free wires left (everythings connected already)and second
I have a rgb fan on the back of the case with a 3pin connector and where the hell do I plug it in lol (second pic)
https://linustechtips.com/topic/1219245-building-a-pc-two-issues/
1 minute ago, ShrimpBrime said:
The G connector is the just to make installation easier. If you don't have these to plug in, they remain blank. You put the wires to the G connector and then plug the connector into the board at the FP pins.
Hey thanks man but what about that 3pin fan connector? I have the 120mm corsair rgb fans. 3 on top ,3 in front,1 in the back and 1 at the bottom of the case. All the fans are connected on the hub but the one on the back (with the 3 pin) I dont know where to plug. I plugged it in the 4pin led pin on the motherboard because I have no clue where it should go lol
I'll have someone else answer that. I don't get into RGB. I'm into CFM.
Have you already used all the chassis fan connectors on your mobo?
Gaming/Editing PC
Motherboard: Asus ROG Strix Z370-E CPU: Intel Core i7-8700K Cooler: EVGA CLC 240 GPU: Asus Dual Edition RTX 2070 Super OC RAM: Corsair Vengeance 16GB @ 3000 MHz PSU: Corsair HX650 Case: Fractal Design Meshify-C White
I connected all my case fans on my Corsair HUB but now I have a back case fan and its connector hanging down  lmao idk where to plug that 3 pin connector I plugged it into a 4pin LED connector on the motherboard
Again, your motherboard should also have chassis fan connectors. Are those all in use? If not you should plug it in there.
Gaming/Editing PC
