So I just received my new RTX 2080 SUPER FE a couple hours ago, and when I try and play a game the CPU and GPU go instantly to 100% or close to it. The max temp I noticed on the GPU was 82C which im sure would have continued to rise if I didn't leave the game.
Specs :
CPU :: i7-9700k @4.6ghz
PSU :: Corsair RM850X
GPU :: RTX 2080 SUPER FE
RAM :: 32GB Vengeance 3000mhz
Most of not all if the games I have played were on high or med/high, cpu temps were fine, and the boost clock of my GPU was at 1950mhz, above what it should be?
I think it might be a motherboard problem, however id rather not buy a new one if possible.
Any suggestions would be welcomed.
I have tried to switch pcie slots.
I have re seated the card multiple times in each slot.
I have changed power settings in nvidia control panel and in battery settings in windows.
I have also tried less GPU intensive games like CSGO which, ran at 80% gpu and 75% cpu.
https://linustechtips.com/topic/1219232-cpu-gpu-at-max-utilization/
Ubisoft is notorious for eating all your resources up in search of getting more frames. My computer does this on Rainbow Six: Siege all the time (8700k + GTX 1080).
What frames are you getting in Division 2?
Fine you want the PSU tier list? Have the PSU tier list: https://linustechtips.com/main/topic/1116640-psu-tier-list-40-rev-103/
Stille (Desktop)
Ryzen 9 3900XT@4.5Ghz - Cryorig H7 Ultimate - 16GB Vengeance LPX 3000Mhz- MSI RTX 3080 Ti Ventus 3x OC - SanDisk Plus 480GB - Crucial MX500 500GB - Intel 660P 1TB SSD - (2x) WD Red 2TB - EVGA G3 650w - Corsair 760T
Evoo Gaming 15"
i7-9750H - 16GB DDR4 - GTX 1660Ti - 480GB SSD M.2 - 1TB 2.5" BX500 SSD
VM + NAS Server (ProxMox 6.3)
1x Xeon E5-2690 v2  - 92GB ECC DDR3 - Quadro 4000 - Dell H310 HBA (Flashed with IT firmware) -500GB Crucial MX500 (Proxmox Host) Kingston 128GB SSD (FreeNAS dev/ID passthrough) - 8x4TB Toshiba N300 HDD
Toys: Ender 3 Pro, Oculus Rift CV1, Oculus Quest 2, about half a dozen raspberry Pis (2b to 4), Arduino Uno, Arduino Mega, Arduino nano (x3), Arduino nano pro, Atomic Pi.
22 minutes ago, Mr Mango said:
140-50+
Yeah. That seems pretty normal to me. Try turning graphics settings up. You should see GPU usage stay near 100 while CPU usage drops.
Stille (Desktop)
Evoo Gaming 15"
