Hi,
For some reason the audio ports on my motherboard have never worked properly so I've been using a cheap USB adapter for the past year but it recently died and I'm looking for a solid replacement because I just realized how bad the audio quality has been so far. So right now I want to invest on a 2.1 set of speakers, but I also want to be able to use my headphones and my microphone. So ideally what I would need is some kind of USB adapter that has at least two audio jack inputs and one microphone input, while delivering an optimal sound quality.
Where can I find such a device, and what other solutions do I have?
Thanks.
https://linustechtips.com/topic/1218198-external-audio-solution/
1 hour ago, IAmAndre said:
Hi,
Thanks.
so you need a headphone out , a line out for the speakers as well as a mic in? what type of mic ,headphones and speakers are you hoping to run?
Yes pretty much. I'm using a Corsair HS50 with the included microphone. So it has a jack that does both input and output but it came bundled with a splitter. I'm also buying speakers from Logitech (not sure about the model yet) that would require a single output jack. I'm considering buying a sound card like this one but I'm not sure if it's worth it, considering that it would cost almost the same price as my speakers.
 Hi If U Want To Get Pretty Hooked Up I Would Still Use The Headphones But Upgrade Ur Microphone I have The Bheringer Euphoria UM2 Has RCA Out And Headphone 8 inch out.
What I Would Do Use the Headphones On The Out Get A Cheap Xlr Mic And Stand And Plug The Logitech Speakers With An Rca To Aux Cable.
What I Use (everything From B&H)
The Euphoria Um2     https://www.bhphotovideo.com/c/product/1056158-REG/behringer_um_2_u_phoria_um2_2x2_usb.html And Its Just 48 Dollars
Microphone Stand      https://www.bhphotovideo.com/c/product/755877-REG/auray_ms_5230f_tripod_microphone_stand.html (This Is The One I Use But I Also Include A Boom Arm)
Boom Arm                  https://www.bhphotovideo.com/c/product/1330668-REG/samson_samba28_mba28_microphone_boom_arm.html
Microphone                https://www.bhphotovideo.com/c/product/68464-REG/Shure_SM58S_SM58S_Cardioid_Dynamic.html   (The One I Use)
Recomended MC       https://www.bhphotovideo.com/c/product/1449997-REG/rode_podmic_dynamic_podcasting_microphone.html
I Hope This Works As A Recomendation
