Hello, need some help to pick a new GPU.
Currently my PC configuration looks like this:
CPU: Intel Core i7 4770
GPU: Sapphire Radeon R9 280
MOBO: Asus Vanguard b85
RAM: Gskill 16GB
SSD: Samsung 860 evo
PSU: TT TP 650 80+ Gold
For last few days my gpu isn't working properly. (Like after 5/6 FIFA games online, the display get nuts, no output) I can't understand whether it's a hardware problem or driver.
In this situation I hope its a driver problem. If not then please suggest me a good value GPU without changing any other components.
My choices are: RTX 1660 or Radeon 5500xt
Keep in mind that I am a 1080p gamer.
Please Suggest me the most compatible one. If you think a there is a better GPU other than this two which will be compatible to my current system please suggest.
Thanks in advance.
https://linustechtips.com/topic/1218161-rtx-or-radeon/
What games do you play? Only Fifa?
In that case maybe a 1650 Super.
Gaming HTPC:
Desktop PC:
Boss-NAS [Build Log]:
Synology-NAS:
DS920+
Audio Gear:
Reviews and Stuff:
Useful Links:
https://linustechtips.com/topic/1218161-rtx-or-radeon/#findComment-13788134
What are they priced at ?
What about the 580 ? And the 1650 super ( basically a 1660 with a smaller frame buffer )
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1218161-rtx-or-radeon/#findComment-13788137
Just now, Ahad4395 said:
Both of them are around $250
And what about a 580 ? And a 1650 super ?
Build Log:
https://linustechtips.com/topic/1218161-rtx-or-radeon/#findComment-13788143
They are around $200
I would consider a 580
It's relatively close to a 5500xt ( if not it's the same performance )
Only problem with it , is that it consumes more power. And tends to run hotter.
Or even a 1650 super which as I said
Is practically a 1660 with a smaller frame buffer.
Build Log:
https://linustechtips.com/topic/1218161-rtx-or-radeon/#findComment-13788158
Thanks for your suggestions. I intended to run this configuration a year or two more. Hopefully this will serve me well.
https://linustechtips.com/topic/1218161-rtx-or-radeon/#findComment-13788172
you can wait for nvidia's 3000 series and maybe get a 3060 so you could have a strong gpu when you upgrade the cpu and other components down the line
if you need a gpu right now then a 1650 super will be a great choice
"I fear not the man who has practiced 10,000 kicks once, but I fear the man who has practiced one kick 10,000 times." - Bruce Lee
https://linustechtips.com/topic/1218161-rtx-or-radeon/#findComment-13788436
