Hello I need help with my Lenovo thinkstation d20, it boot up to this screen and says keyboard error and to continue boot i need to press f2 but the keyboard doesn't work. I tried resetting bios , tried replacing cmos battery and the same problem, has anyone has an idea how to fix this
https://linustechtips.com/topic/1218015-help-problem-with-lenovo-d20/
Seeing multiple errors starting with disk errors.  suspecting OS corruption
Won't make a difference for BIOS. Lenovo/IBM systems will complain about all manner of things when the BIOS is reset
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
8 minutes ago, Jareoz said:
No
Ok, what happens if you plug a keyboard in *after* the BIOS throws all kinds of errors?
Does the keyboard light up for the caps lock or num lock, when you press them?
6 hours ago, Jareoz said:
No the keyboard doesn't light up
Sounds like the chip controlling the USB has died.
Buy a PCI USB card as an add-in, might be the only way.
