I had my PC built by IBP around three years ago and I've decided to upgrade my gpu to a EVGA GeForce RTX 2070 SUPER KO GAMING Video Card, 08G-P4-2072-KR, 8GB GDDR6. I read in the product info that it requires a pci-e 8 pin and a 6 pin. I have a Inwin c900W, when my pc was built IBP never sent the extra modular cables so I only have the one cable for my gpu now which is a 1060 which takes a 6 pin and the one plugged in is a 6+2 pin cable. So my question is what cable do I need to buy that will be compatible with my power supply and should I either buy another 6 pin or just buy one cable that has dual 8+6. If you can send me some amazon links on what cables to buy it would be very appreciated.
https://linustechtips.com/topic/1217794-half-gpu-half-power-supply-question/
You can just buy an extra 6+2 pin pcie
Cable , as to where to buy it
I don't know the pin layout and I can't find any cables as stand alone products that you can buy. ( I could have missed it.)
Phone: Pixel 3a (Purple-ish).
Build Log:
I'd try contacting in-win to see if they could send or sell you one
Bethesda PC:   R7 3700X  -  Asrock B550 Extreme 4  -  Corsair Dominator Platinum RGB 16GB@3.6GHz -  Zotac AMP Extreme 1080TI -  Samsung 860 Evo 256GB  -  WD Blue 2TB SSD -  500DX  -  Stock cooling lul  -  Rm650x
CrumpleBox V3:  Xeon X5680  -  Asus X58 Sabertooth  -  DDr3 16GB@1.33Ghz  -  Gigabyte 1660s -  TT smart RGB 700W  -
Cooler Master Storm Trooper  -  120GB Samsung 850 Pro   -  LTT Edition Chromax NH-D15 ?
CrumpleBox 3 ROTF: I5-6400  -  MSI B150m Mortar  -  16GB 2133Mhz Vengeance Pro RGB  -  Strix 1070Ti - GTX 1070 FE  -  Adata 128GB SSD  -  Fractal Design Define C  -  Gammaxx 400V2  -  Cooler Master silent pro gold 1000W
CrumpleBox 2: i7-7820x - MSI X299 Raider - 32GB Thermaltake Toughram 3.6Ghz - 2x Sapphire Nitro Fury - 128GB PCie Adata SSD - O11 Dynamic - EVGA CLC 360 - Corsair RM1000X
Perhiperals:  Gateway 900p60 monitor  -  Dell 1024x768@75  -  Logi. G403 Carbon  -  Logi. G502  -  SteSer. Arctis 5  -  SteSer. Rival 110 - Corsair Strafe RGB MK.2
2 hours ago, 5x5 said:
That is not a 900W power supply, it can barely output 400W. Do NOT use it as it WILL destroy the system. Since it has no protections whatsoever and is abysmal quality.
I've had this pc for years and never had any issues and im pretty sure my current system would brick a 400w
I'm just worried as on amazon some stand alone cables being sold say they're for specific brands, for example, one said for corsair and i think the end that goes into the power supply isnt actually a normal pci-e as corsair is different. I just don't want to buy the wrong cable
The ATX end ( the one that plugs to your components ) is standard
The one that plugs to your PSU is not.
Build Log:
