Raspberry pi - need to automatically start bluetooth start pulseaudio
steelo
Hey guys,
I'm working on a voice changer project with a rpi zero w where I'm trying to connect to a bluetooth speaker. As you probably already know, the zero only has 1 available usb port so I am forced to use a bt speaker. I can manually type in bluethothctl power on, agent on, pair, connect and then start pulseaudio --start. However, how would I go about doing this at boot with something like a python script? I found a few guides online but none of them properly connect my speaker. Also, even when doing this manually it's really flaky whether it wants to connect to the speaker.
Thanks!
3 minutes ago, Sauron said:
https://wiki.archlinux.org/index.php/bluetooth#Auto_power-on_after_boot
Everything you need should be on that page.
Thanks, this is one of the guides I followed. However I can't figure out which step is missing. If I do this manually, it works 75% of the time. I need to figure out which step differs from when I manually go through the process...
Well... no step should be missing. Try debugging https://wiki.archlinux.org/index.php/bluetooth#Debugging
sudo chmod -R 000 /*
Now, it's not even wanting to connect manually. It worked almost perfectly last night...I'm trying to connect to device FC:58:FA...As you can see, it will briefly pair to Hex Spkr and then almost immediately disconnect...then, it won't connect
Seems more of a problem with your speaker than your pi...
That's what I'm wondering...this was a $5 special at Five Below. What's interesting though is it works perfectly with my Android phone and my wifes iphone. I may just have to buy a mic and speaker with a 3.5mm jack to plug into a usb sound card. I was trying to have as few parts as possible so it's easily concealable.
