So recently I finally bit the bullet and bought an entry-level gaming PC for around $800 (US). I'm a fairly broke teen who doesn't like spending money often so I'd been putting off upgrading my potatotop for a while. It's an Asus PC, and has RGB built in (albeit not the brightest or fanciest, it's mostly just a nice touch), which is of course compatible with Aura Sync. I know I could've gotten way better value going prebuilt, but sometimes you just can't convince tech-ignorant parents that it's a super simple process haha. But regardless, I finally have a competent gaming setup. I'm working this summer and plan to upgrade as I can afford it (Swapping out the 8 GB stick of memory for a couple of sticks of Vengeance or Ripjaws, perhaps even RGB memory, down the line, and maybe some new RGB case fans that are quieter). So, anyway, I digress. What I'm writing this topic for is to ask is if there is any way possible to hook up external (like those strips that go on the wall or the equivalent) RGB lights to sync up with Aura Sync. I wouldn't even know what to search for on Amazon or Newegg, so I decided to consult the forum. I'm assuming they would need to carry some sort of Bluetooth (which my PC has) or USB and somehow be able to tie into Aura Sync. If it's not possible or downright expensive/tedious, oh well, no biggie, separate RGB lights for my setup are always an option, but I was just curious if this is at all possible. Thanks for any help you all can give!
https://linustechtips.com/topic/1216948-external-rgb-compatible-with-aura-sync/
I believe Phillips hue can still sync with ASUS Aura, though id imagine it would be fairly expensive.
https://www.asus.com/support/FAQ/1036368/
There used to be a ASUS ROG Aura USB Terminal that came with light strips, I however don't see it in stock anywhere. May be discontinued.
https://www.asus.com/us/ROG-Republic-Of-Gamers/ROG-Aura-Terminal/
