How do i delete another OS from another drive
By
ChrisElitz
in Windows
in Windows
Solved by ChrisElitz,
1 minute ago, homeap5 said:Separate thread for the same problem? Man, just use explorer and delete anything you want from second drive if you must do that.
Yeah ok I'll marked this as solved I won't format nor delete windows anyways
Featured Topics
Pove ·
Posted in New Builds and Planning1 -
Knugen1015 ·
Posted in Windows0 -
1
2
1
9
munem939 ·
Posted in Power Supplies1 -
6
1
6g2 ·
Posted in Troubleshooting2
