Use hwinfo64 or cpu-z to monitor the frequency
Also 5.1 is totally achievable with a 9700k
1 minute ago, Marshg3 said:
have the gamers overclock
What does that mean
And at what voltage ?
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1216323-are-speed-ok/#findComment-13772958
18 minutes ago, Marshg3 said:
-snip-
Use hwinfo64 to check the frequency and the voltage
As I said the 9700k can absolutely achieve 5.1
Do a stress test monitoring both voltage and temps
Build Log:
https://linustechtips.com/topic/1216323-are-speed-ok/#findComment-13773020
