Hello, I have some problems with P106-90. I tried to install drivers, 417.22. It shows up like this, is there any solution ? I have tried DDU, changing things in nv_dispi. Thanks in advance
My system
PSU: Thermaltake Smart M 650W
CPU: Ryzen 3 2200G
Mobo: MSI B350M Gaming Pro
Ram: Crucial 8GB 2666 CL19
GPU: Zotac P106-90
https://linustechtips.com/topic/1216129-problem-with-p106-90/
It's a mining card
Not made to download drivers or display an image even
You would have to make some modifications to it, to be able to install drivers iirc
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1216129-problem-with-p106-90/#findComment-13771134
  • 3 months later...
My system
CPU: Ryzen 3 2200G
GPU: Zotac P106-90
@Enormousdid you manage to make it work?
https://linustechtips.com/topic/1216129-problem-with-p106-90/#findComment-14103380
  • 6 months later...
  • 1 month later...
