Hey. I'm having issues with mouse stutter in games (for example Valorant, never happened in dekstop).
I hope the video can showcase it well enough (the mouse movement was one smooth motion, the mouse was stopping sometimes by itself).
At first i thought that it's a mouse problem so I switched from Logitech G403 to Razer Viper, the problem still existed.
I tried switching my polling ratio to 125Hz, 250Hz, 500Hz, 1000Hz, and that didn't help. Changing my NVidia control panel settings or lowering resolution and lowering graphics quality didn't help.
I switched my mousepad to a different one, used multiple surfaces and I still had that problem. I have no idea what could be the issue that's causing it. I also reinstalled my windows, cleaned it up too.
I reinstalled Valorant still to no success.
If anyone had that problem or could find a solution I would be forever grateful.
Here are my PC Specs:
Motherboard Chipset Intel H97
Processor i5-4460 (3.2 GHz, 3.4 GHz Turbo, 6 MB Cache, 84W)
RAM 8 GB DDR3-1600 (PC3-12800)
Graphics Card NVidia GeForce GTX 1060 6 GB
https://linustechtips.com/topic/1216117-need-help-with-mouse-stutter/
4 minutes ago, Jake Likes Tech said:
Did this start randomly or when you got it?
It has been happening for a few months now. At first I thought it was a Logitech G403 faulty sensor problem but after those months passed I got a Razer Viper and the issue still persists.
It's the game.  I noticed stuttering even when the FPS is sky high.  The engine isn't super optimized yet.  You can test this by going into the training area where you shoot all the strafing bots.  Use Brimstone and just spam at the bots and start swiping your mouse.  You will notice massive random "stuck" moments. It's the game, it isn't you.
QUOTE ME IN A REPLY SO I CAN SEE THE NOTIFICATION!
When there is no danger of failure there is no pleasure in success.
I really hope it's not my specs failing. I've read somewhere that High Priority should help with that. Is anyone able to confirm that? Also when there is a lot of utility thrown like sage ice and smokes I can barely move my mouse at all. On the other hand I think it happened to me in different games too but I'm not really sure since I haven't played any other game since Valorant first came out in the beta.
It's not your hardware.  I'm on a 3700x and a 1070 and get anywhere between 150-300fps and the stutter exists.
Ohh okay. Was there any fix found for that or is it something that the devs need to resolve?
I haven't done extensive research on whether this impacts more than just me, but I also don't play Valorant often so I just never had the initiative to go and fin a fix yet.
Okay, thank You for pointing out the reason anyway. If anyone knows the fix I would be grateful.
Maybe try disabling Mouse Acceleration under "Advanced Mouse Settings". Usually isn't the culprit but it's happened to me.
Thank You for the reply but that isn't the culprit of that problem. I never used Mouse Acceleration was always off.
