hey my gpu is gigabyte rx570, the issue i am facing is when io connect to a hdmi slot of the gpu the monitor shows no signal, but when i connect vga into the motherboard it just works fine and the gpu rgb light is also blinking
my computer configuration is:
i3 3220 processor
6 gb ddr3 ram
gigabyte radeon rx 570 4 gb gpu
 please help me out
https://linustechtips.com/topic/1214970-rx-570-issue/
So your i-gpu is working but your dgpu isn't ?
Am I getting this correctly ?
If so
Make sure the pcie cable is properly connected
Re seat the GPU
Make sure it's at least detected
Phone: Pixel 3a (Purple-ish).
Build Log:
https://linustechtips.com/topic/1214970-rx-570-issue/#findComment-13762703
i3 3220 processor
6 gb ddr3 ram
 please help me out
Can you see the 570 in device manager when running of VGA?
I will recommend an NHu12s (or an NHd15 (maybe)) for your PC build. Quote or @ me @Prodigy_Smit for me to see your replies.
PSU Teir List | Howdy! A Windows Hello Alternative
Desktop :
i7 8700 | Quadro P4000 8GB |  64gb 2933Mhz cl18 | 500 GB Samsung 960 Pro | 1tb SSD Samsung 850 evo
Laptop :
ASUS G14 | R9 5900hs | RTX 3060 | 16GB 3200Mhz | 1 TB SSD
https://linustechtips.com/topic/1214970-rx-570-issue/#findComment-13762709
