Hi
yesterday i built a new system for my girlfriend.
Specs:
i5 9600K*
with Alpenfön Sella Cooler
ASUS ROG Z390-F*
Zotac 1060 6Gb
2x8 Gb HyperX Fury*
Seasonic PX 650 Plus Pt*
Samsung 970 EVO  - 1 TB
Sasmsung 850 - 500 GB
Seagate Baracuda 1 TB
Seagate 500 GB
in a Zalman S5 Case
*bought used
I did a new install of windows 10 onto the NVMe Drive and migrated some programs to it or reinstalled.
I didn't played a game or did more than some installations.
So today i wanted to test some stability and GPU was stable under Furmark.
When i tried to stress the CPU with Prime95 i got a bluescreen...
Because i read that Prime95 could be to hard, i tried the benchmark of the Intel Extreme Tunining Utility and same result -> Bluescreen...
I double Checked the CPU-Cooler and it looked like it is enough TIM and i also tightened the cooler evenly..
Do you guys have any ideas what i can try next?
BIOS is on the latest version and i didnt changed anything in it
https://linustechtips.com/topic/1214919-solved-stability-problems/
What voltage do you have set ?
What are your temps?
Monitor this with hwinfo64
Phone: Pixel 3a (Purple-ish).
Build Log:
3 minutes ago, turtles_vrywhr said:
-snip-
What are your temps when you stress test ?
Build Log:
All Core +-50 °C
Run memtest86 and OCCT to make sure it's not a memory problem
If it's not
Clear the cmos and then try the stress test ( without xmp)
Build Log:
If it's not
OCCT crashed after 1 min without finding an error https://cloud.tmaex.com/s/ZCrPZCsNbRFEsDX
What about memtest86 ?
Build Log:
1 minute ago, turtles_vrywhr said:
crashed after 3 minutes at this screen
-snip-
Clear the cmos
Disable xmp
Inspect the board for any bent pins
Build Log:
Appears to be RAM related BSoD / errors.
AMD Ryzen 9000 Rig
  • Lian-Li O11 Dynamic EVO XL
AMD Ryzen 5000 Rig
  • AMD R7-5800X
  • Gigabyte B550 Aorus Pro AC
  • EKwb D-RGB 360mm AIO
i will do this after my online lectures. @TofuHaroto Pins were fine. I had the seller send me a picutes befor i bought the board and inspected it right, when i got it.
I will clear the cmos then and i think XMP isn't even enabled but i'll double check that.
And then i will probably get 2 sticks out of my rig and try it with those.
Any suggestions i can try to solve those errors?
Slowly raise the RAM speed until you either hit the advertised speeds of the RAM kit or you fail to boot, then you raise the voltage (up by 0.025 volts at a time) until you boot and stress test.
1 hour ago, turtles_vrywhr said:
It actually seems like the ram isnt supported by the motherboard. Its HX432C16FB3K2/16 and this particular Kit isnt mentioned in the Memory-Support list by Asus.
There is a 99% chance that it works fine, the only reason is that Asus can't test every single RAM kit in the world.
