Is there a difference between the cooler on an old pentium (E5300) and a i5 3570k? I would assume yes, but an answer would be great.
Athlon X4 760K | MSI A88X-G43 | 8GB G.Skill Ripjaws 1333Mhz | MSI R7 260X 2GB | Corsair 300R | Corsair CX430 | 640GB HDD | Windows 7 64-bit
HP W2071d 20" 900p TN | Stock Dell K/B | Microsoft Comfort Optical Mouse 3000 + SteelSeries Qck Portal 2 Ed. | Grado SR80i + cheap 2.0 speakers
https://linustechtips.com/topic/121489-stock-cooler-difference/
Anybody know? It would be helpful to run on the stock cool that I have until I can get a nicer one.
https://linustechtips.com/topic/121489-stock-cooler-difference/#findComment-1617539
Bought it used so no.
https://linustechtips.com/topic/121489-stock-cooler-difference/#findComment-1617565
If the holes line up do you think it would work? I know AMD has different stock coolers and they all look the same to me. So I don't know if there is difference between a pentium cooler and a i5 cooler.
https://linustechtips.com/topic/121489-stock-cooler-difference/#findComment-1617582
Its 775 vs 1155 not 1155 vs 1150
https://linustechtips.com/topic/121489-stock-cooler-difference/#findComment-1617599
Can't you just try it out? The TDP of the E5300 is 65 W according to Intel's ark,
which is pretty close to the 3570k's 77 W. So as long as you don't overvolt, the
cooler should be able to dissipate the heat from a 3570k. Keep an eye on temps
just to be sure (if the mounting system is compatible).
PS: I don't think there's a need to bump threads so quickly. A bit of patience goes
a long way. ;)
BUILD LOGS: HELIOS - Latest Update: 2015-SEP-06 ::: ZEUS - BOTW 2013-JUN-28 ::: APOLLO - Complete: 2014-MAY-10
OTHER STUFF: Cable Lacing Tutorial ::: What Is ZFS? ::: mincss Primer ::: LSI RAID Card Flashing Tutorial
FORUM INFO: Community Standards ::: The Moderating Team ::: 10TB+ Storage Showoff Topic
https://linustechtips.com/topic/121489-stock-cooler-difference/#findComment-1617618
a long way. ;)
Thank You, I will just try it.
And yeah I am feeling impatient today, tests and homework without sleep is not good.
https://linustechtips.com/topic/121489-stock-cooler-difference/#findComment-1617633
