hey guys I am just finishing up my new gaming rig and I was curious how far can i push the athlon x4 750k? got a nice fm2 mobo and this zalman heat sink.
http://www.newegg.com/Product/Product.aspx?Item=N82E16835118128
there is no documentation online that i could find and what little bit i did was garbage and said 5 ghz on air lol! i was thinking push it to 4.5? maybe 4.6 ????
https://linustechtips.com/topic/121478-overclocking-help/
It all depends on what your chip can handle. The only way to find out is trial and error so keep raising that frequency and tinkering with that V core until it crashes or gets too hot :D
        | 5820k+EK supremacy nickel+acetal white 4.5Ghz | X99 Deluxe | Enthoo Luxe | 2x gtx780+komod NV full cover block | Corsair AX1200i | WD blue 500gb |
        Kingston V300 120gb | Samsung 840 Evo 500gb| Bitspower D5 vario+Res combo | primochill advanced LRT tubing (Solid White) |
        | Alphacool Nexxos MONSTA dual 120mm Black Ice nemesis GTX360 triple 120mm | Noctua NF-F12 X4 | Bitspower true silver 1/2ID 3/4 OD compressions (various angles) |
https://linustechtips.com/topic/121478-overclocking-help/#findComment-1617317
With that cooler, I think 4.5GHz will be the absolute maximum that you can achieve. Sorry mate, but that just isn't a performance cooler. You could achieve 5GHz on air, but maybe with a NHD-14 or something like that. Of course it all depends on your chip as well so...
CPU: AMD Ryzen 9 - 3900x @ 4.4GHz with a Custom Loop | MBO: ASUS Crosshair VI Extreme | RAM: 4x4GB Apacer 2666MHz overclocked to 3933MHz with OCZ Reaper HPC Heatsinks | GPU: PowerColor Red Devil 6900XT | SSDs: Intel 660P 512GB SSD and Intel 660P 1TB SSD | HDD: 2x WD Black 6TB and Seagate Backup Plus 8TB External Drive | PSU: Corsair RM1000i | Case: Cooler Master C700P Black Edition | Build Log: here
https://linustechtips.com/topic/121478-overclocking-help/#findComment-1617320
