Hi LLT.
I've acquired a new itx case and have swapped components around from a former ITX build to a new case (Evolv Shift Air).
Things I've swapped over from the former build is Mobo, RAM, CPU and GPU.
New things, PSU (Corsair SSF 750watt) and CPU cooler (Noctua L12s).
I had the build up and running managed to install windows 10 with just the basics connected.
Powered down and wanted to connect all fans / case connections and a different GPU.
Now I can't get any sign of life out of the system, tried swapping back to the previous GPU, the old system powersupply (corsair TX650m).
My guess is the mobo has died in the process somehow. I've yet to check if the Riser Cable for the GPU could be the reason but then FANs would at least start spinning right?
Cheers.
https://linustechtips.com/topic/1214616-nothing-happens-when-pressing-power-button/
make sure that your stuff is all plugged in properly. like the power button and all that good stuff
PC specs:
Ryzen 9 3900X overclocked to 4.3-4.4 GHz
Corsair H100i platinum
32 GB Trident Z RGB 3200 MHz 14-14-14-34
RTX 2060
MSI MPG X570 Gaming Edge wifi
NZXT H510
Samsung 860 EVO 500GB
2 TB WD hard drive
Corsair RM 750 Watt
ASUS ROG PG248Q
Razer Ornata Chroma
Razer Firefly
Razer Deathadder 2013
Logitech G935 Wireless
16 minutes ago, QuackAFQuack said:
Hi LLT.
Cheers.
Try plugging out everything and holding down the power button a couple of seconds and replugging everything and try starting.
PM/DM me if you have any questions about audio.
My PC specs & audio gear
CPU > Intel core i7 14700K, GPU > RTX 4070 ProArt, RAM > Corsair Vengeance DDR5 2x16gb 5600mhz, Motherboard > Asus ROG Strix B760-F, Storage > 1TB M.2  & 500GB M.2 Kingston, Cooling > H150i Elite, PSU > MSI A850GL
🎧Current Audio Setup🎧
HifiMan Ananda Nano, HE400se, X2HR
Soundblaster AE-9 Soundcard
AKG P420 Mic
Other peripherals
Monitor > Samsung Odyssey OLED G9
Keyboard > Keychron Q3 HE TKL
Mouse > Logitech G Pro 2 Lightspeed
Mousepad > X-Gamer XG++ XXL mousepad
Read this post if you want a "gaming" headset ;)
9 minutes ago, emosun said:
Bench test the board and psu by themselves outside the case with only cpu installed
moved the mobo to the old case (SilverStone SG13) and plugged the old PSU. Having only the CPU and RAM on the board no life sign from pressing power button.
